[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Fri Nov 4 07:51:11 PDT 2022
  Reporter:  louisd    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.2.4
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:  make install topology error
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"6b2d4309836f6e8d1a07496b7317f9ce03192ada/git" 6b2d430/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6b2d4309836f6e8d1a07496b7317f9ce03192ada"
 Fix topology install on Alpine
 Move include $(PGXS) and use := for LIBTOOL
 References #5264 in 3.3 branch (3.3.2dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:16>
