[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Fri Nov 4 07:53:22 PDT 2022
  Reporter:  louisd    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.2.4
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:  make install topology error
Comment (by strk):
 I've backported the patch to stable-3.3 branch but it doesn't apply
 cleanly on the stable-3.2 branch, can you check if stable-3.2 branch
 builds fine on alpine ? There's no LIBTOOL at all defined in there
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:17>
