[postgis-tickets] [PostGIS] #5284: Cannot restore topology dumps with layers having renamed topogeom column
PostGIS trac at osgeo.org
Tue Nov 8 00:22:08 PST 2022
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.3.2
Component:  topology  |    Version:  3.3.x
 Keywords:            |
 When renaming a topogeometry column the constraint used to check its
 topology and layer identifiers keeps the old name but the pgtopo_import
 does not expect this, resulting in it not being able to disable the check.
 In turn, not disabling the check results in an exception thrown upon
 populating the layer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5284>
