[postgis-tickets] [PostGIS] #5284: Cannot restore topology dumps with layers having renamed topogeom column
PostGIS trac at osgeo.org
Thu Nov 10 08:15:40 PST 2022
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.3.2
 Component:  topology  |    Version:  3.3.x
Resolution:            |   Keywords:
Comment (by strk):
 NOTE: you need to have data in the layer in order for this problem to be
 reproducible (and as a work around you would need to edit the SQL dump to
 not create the constraint)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5284#comment:1>
