[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-330-gb4e198bf3
Wed Nov 9 01:47:32 PST 2022
the project "PostGIS".
       via  b4e198bf3c6e3fb6a462930ba477c4e30d96e22f (commit)
      from  86d6b1b55bdeb71819b86a028e70c888c05c907f (commit)
revisions in full, below.
commit b4e198bf3c6e3fb6a462930ba477c4e30d96e22f
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 8 11:41:15 2022 +0100
    Always test upgrades in presence of ST_Union based view
    Even when running in PostgreSQL < 12
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index e5a78de74..12105de01 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -3,27 +3,10 @@ INSERT INTO upgrade_test(g1,g2) VALUES
 ('POINT(0 0)', 'LINESTRING(0 0, 1 1)'),
 ('POINT(1 0)', 'LINESTRING(0 1, 1 1)');
--- We know upgrading with an st_union() based view
--- fails unless you're on PostgreSQL 12, so we don't
--- even try that.
--- We could re-enable this test IF we fix the upgrade
--- in pre-12 versions. Refer to
--- https://trac.osgeo.org/postgis/ticket/4386
-DO $BODY$
-DECLARE
-	vernum INT;
-BEGIN
-	show server_version_num INTO vernum;
-	IF vernum >= 120000
-	THEN
-		RAISE DEBUG '12+ server (%)', vernum;
-    CREATE VIEW upgrade_view_test_union AS
-    SELECT ST_Union(g1) FROM upgrade_test;
-	END IF;
-END;
-$BODY$ LANGUAGE 'plpgsql';
+-- Add view using ST_Union aggregate
+-- See https://trac.osgeo.org/postgis/ticket/4386
+CREATE VIEW upgrade_view_test_union AS
+SELECT ST_Union(g1) FROM upgrade_test;
 -- Add view using overlay functions
 CREATE VIEW upgrade_view_test_overlay AS
Summary of changes:
 regress/hooks/hook-before-upgrade.sql | 25 ++++---------------------
 1 file changed, 4 insertions(+), 21 deletions(-)
hooks/post-receive
