[postgis-tickets] [PostGIS] #5269: Berrie failing on installing shp2pgsql pgsql2shp
PostGIS trac at osgeo.org
Wed Nov 9 02:06:50 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Old description:
> 05:55:07 ---- Making install in loader
> 05:55:07 make[1]: Entering directory
> '/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie/8a73d5ee4ea69f318deda4ad3f72ee4cb5f20371/loader'
> 05:55:07 /bin/bash ../libtool --mode=install /usr/bin/install -c
> pgsql2shp "/usr/local/bin/pgsql2shp"
> 05:55:07 libtool: install: /usr/bin/install -c pgsql2shp
> 05:55:07 /usr/bin/install: cannot create regular file
> '/usr/local/bin/pgsql2shp': Permission denied
> 05:55:07 make[1]: *** [Makefile:148: install] Error 1
> 05:55:07 make[1]: Leaving directory
> 05:55:07 make: *** [GNUmakefile:25: install] Error 1
> 05:55:08 Build step 'Execute shell' marked build as failure
> 05:55:13 Finished: FAILURE
> I assume this is a result of this:
> [8a73d5ee4e/git]
> So the cis need to be changed to now use the prefix
New description:
 05:55:07 /bin/bash ../libtool --mode=install /usr/bin/install -c pgsql2shp
 [8a73d5ee4e/git]
Comment (by strk):
 I think you want to omit the /bin part from the --prefix (or you'd end up
 installing in bin/bin)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5269#comment:2>
