[postgis-tickets] [PostGIS] #5269: Berrie failing on installing shp2pgsql pgsql2shp
PostGIS trac at osgeo.org
Wed Nov 9 02:07:07 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 Use --bindir if you only want to tweak the binaries installation
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5269#comment:3>
