[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-337-gc7c9e2225
Mon Nov 14 17:26:26 PST 2022
the project "PostGIS".
       via  c7c9e22255696e1461aeeb96b424ff2e22b45468 (commit)
       via  996970f6d0d01be6ad7fa4673ecb6c71c91dacdc (commit)
      from  ae95dd219b2db85289452ca5725d87df32320d3c (commit)
revisions in full, below.
commit c7c9e22255696e1461aeeb96b424ff2e22b45468
Author: Hannes <kannes at users.noreply.github.com>
Date:   Tue Nov 1 20:28:16 2022 +0100
    Include example of ST_Disjoint = NOT ST_Intersects
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index bd033cf30..19915df6b 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -794,7 +794,8 @@ WHERE ST_Crosses(roads.geom, highways.geom);</programlisting>
       <para>Performed by the GEOS module</para>
       <note>
         <para>This function call does not use indexes. A negated <xref linkend="ST_Intersects" /> predicate
-          can be used as a more performant alternative that uses indexes.</para>
+          can be used as a more performant alternative that uses indexes:
+          <code>ST_Disjoint(A,B) = NOT ST_Intersects(A,B)</code></para>
       </note>
       <note>
commit 996970f6d0d01be6ad7fa4673ecb6c71c91dacdc
Date:   Mon Oct 31 20:10:37 2022 +0100
    Mention "NOT ST_Intersects" as index-using alternative to ST_Disjoint
    Ref https://twitter.com/cartocalypse/status/1585223073418350593
index 97fcc3ba3..bd033cf30 100644
@@ -793,7 +793,8 @@ WHERE ST_Crosses(roads.geom, highways.geom);</programlisting>
       <note>
-        <para>This function call does not use indexes</para>
+        <para>This function call does not use indexes. A negated <xref linkend="ST_Intersects" /> predicate
+          can be used as a more performant alternative that uses indexes.</para>
       </note>
       <note>
Summary of changes:
 doc/reference_relationship.xml | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
