[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-345-g661ae91d8
Wed Nov 23 14:41:07 PST 2022
the project "PostGIS".
       via  661ae91d8fca033a39d09fe49a6e927da8003da3 (commit)
      from  9430d7dbb6d3b2a3c28b90dddf6e8ea83fbbc810 (commit)
revisions in full, below.
commit 661ae91d8fca033a39d09fe49a6e927da8003da3
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Nov 23 14:41:03 2022 -0800
    Improve doc for ST_GeoHash
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 9c10d9204..39dfcdbc5 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1845,16 +1845,20 @@ x3dfrag
 		<title>Description</title>
 		<para>Computes a <ulink url="http://en.wikipedia.org/wiki/Geohash">GeoHash</ulink> representation of a geometry.
-        A GeoHash encodes a geometry into a text form that is sortable and searchable based on prefixing.
-        The GeoHash code maps to a cell in the hierarchical GeoHash grid that contains the geographic extent (box) of the geometry.
-        A shorter (less precise) GeoHash code maps to a larger cell containing the geometry.
+        A GeoHash encodes a geographic Point into a text form that is sortable and searchable based on prefixing.
+        A shorter GeoHash is a less precise representation of a point.
+        It can be thought of as a box that contains the point.
+        </para>
+        <para>Non-point geometry values with non-zero extent can also be mapped to GeoHash codes.
+        The precision of the code depends on the geographic extent of the geometry.
         </para>
 		<para>If <varname>maxchars</varname> is not specified, the returned GeoHash code is for the smallest cell containing the input geometry.
         Points return a GeoHash with 20 characters of precision (about enough to hold the full double precision of the input).
-        Other types may return a GeoHash with less precision, based on the extent of the geometry.
+        Other geometric types may return a GeoHash with less precision, depending on the extent of the geometry.
         Larger geometries are represented with less precision, smaller ones with more precision.
-        The cell mapped to by the GeoHash code always contains the input feature.</para>
+        The box determined by the GeoHash code always contains the input feature.</para>
 		<para>If <varname>maxchars</varname> is specified the returned GeoHash code has at most that many characters.
         It maps to a (possibly) lower precision representation of the input geometry.
Summary of changes:
 doc/reference_output.xml | 14 +++++++++-----
 1 file changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
