[postgis-tickets] [PostGIS] #5291: berrie64 crashing on postgis raster tests
PostGIS trac at osgeo.org
Fri Nov 25 10:48:52 PST 2022
 Reporter:  robe    |      Owner:  robe
     Type:  defect  |     Status:  new
 Priority:  high    |  Milestone:  PostGIS 3.4.0
Component:  raster  |    Version:  master
 Keywords:          |
 berrie seems to be okay so might be something specific about berrie64.
 The crashing query is:
                 SELECT ST_Neighborhood(rast1.rast,
 ST_Centroid(rast1.rast::geometry), 100, 100, false)
                         , ST_AsEWKT(rast1.rast::geometry) As ref1_geom,
 ST_AsEWKT(rast2.rast::geometry) As ref2_geom
                                         FROM (
                         (SELECT
 ST_SetSRID(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster( 10, 10, (i-1)*10,
 (i-1)*10, 0.0005, -0.0005, 0*i, 0*i), '64BF'), i, (i+1),42949.12345),4326)
 As rast
                                 FROM generate_series(1,2) As i)
                  ) As rast1 CROSS JOIN (
                         (SELECT
 (i-1)*10, 0.0005, -0.0005, 0*i, 0*i), '32BUI'), i, (i+1),42949),4326) As
 rast
                  ) As rast2
                                         LIMIT 2;
 What's odd about this is that the query passes and runs but then next
 output is
 WARNING:  terminating connection due to immediate shutdown command
                         UPDATE raster_garden_log33 SET log_end =
 clock_timestamp()
                 FROM (SELECT logid FROM raster_garden_log33 ORDER BY logid
 DESC limit 1) As foo
                 WHERE raster_garden_log33.logid = foo.logid  AND
 raster_garden_log33.log_end IS NULL;
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 connection to server was lost
 Same maybe this is just server exhaustion and berrie64 needs a reboot.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5291>
