[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Sat Oct 1 14:22:44 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 I guess we don't have a test for this cause the test should have caught
 it.
 When I run this on my setup after a fresh install of 3.4.0dev
 SELECT postgis_extensions_upgrade();
 I get this error:
 NOTICE:  Updating extension postgis 3.4.0dev
 ERROR:  syntax error at or near "ANY"
 LINE 1: ...TENSION "ALTER EXTENSION %1$I UPDATE TO %2$I" UPDATE TO ANY;
 QUERY:  ALTER EXTENSION "ALTER EXTENSION %1$I UPDATE TO %2$I" UPDATE TO
 ANY;
 CONTEXT:  PL/pgSQL function postgis_extensions_upgrade() line 89 at
 EXECUTE
 SQL state: 42601
 On closer inspection, the problem is this format expression:
                         sql = format(
                                 'ALTER EXTENSION %1$I UPDATE TO ANY;',
                                 'ALTER EXTENSION %1$I UPDATE TO %2$I',
                                 rec.name, target_version
 I think should be:
                         sql = format(
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253>
