[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Sat Oct 1 14:27:28 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Description changed by robe:
Old description:
> I guess we don't have a test for this cause the test should have caught
> it.
> When I run this on my setup after a fresh install of 3.4.0dev
> SELECT postgis_extensions_upgrade();
> I get this error:
> NOTICE:  Updating extension postgis 3.4.0dev
> ERROR:  syntax error at or near "ANY"
> LINE 1: ...TENSION "ALTER EXTENSION %1$I UPDATE TO %2$I" UPDATE TO ANY;
> QUERY:  ALTER EXTENSION "ALTER EXTENSION %1$I UPDATE TO %2$I" UPDATE TO
> ANY;
> CONTEXT:  PL/pgSQL function postgis_extensions_upgrade() line 89 at
> EXECUTE
> SQL state: 42601
> On closer inspection, the problem is this format expression:
>                         sql = format(
>                                 'ALTER EXTENSION %1$I UPDATE TO ANY;',
>                                 'ALTER EXTENSION %1$I UPDATE TO %2$I',
>                                 rec.name, target_version
> I think should be:
>                         sql = format(
New description:
 it.
 I get this error:
 ANY;
 EXECUTE
 SQL state: 42601
                         sql = format(
                                 'ALTER EXTENSION %1$I UPDATE TO "ANY";',
 I think should be:
                         sql = format(
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253#comment:1>
