[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Sat Oct 1 18:25:32 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"138d591dff88034d803abe8f30e6e495783bf17b/git"
 138d591d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="138d591dff88034d803abe8f30e6e495783bf17b"
 Fix postgis_extensions_upgrade for same version to same version.
 Tests still needed
 References #5253 for PostGIS 3.4.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253#comment:4>
