[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Sun Oct 2 03:39:40 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 strk mentioned there is a test, but it appears no bots are testing it.
 I was able to do a test with
 perl regress/run_test.pl --extension -v --upgrade-path "3.4.0dev--:auto!"
 regress/loader/Polygon
 To confirm that the before failed and the patched works.
 I'll an auto upgrade test to GHA
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253#comment:5>
