[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Sun Oct 2 04:05:55 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"34ddeb15fc9b9c357b801f3773db787fa4a1e099/git"
 34ddeb15/git]:
 {{{#!CommitTicketReference repository="git"
 revision="34ddeb15fc9b9c357b801f3773db787fa4a1e099"
 1) Oops forgot to declare from version.
 2) Add extension SELECT postgis_extensions_upgrade() to dronie
 Closes  #5253 for PostGIS 3.4.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253#comment:6>
