[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Sun Oct 2 04:15:29 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"9c6143992817fbc2b5348e3563b07edf54283af4/git" 9c61439/git]:
 {{{#!CommitTicketReference repository="git"
 revision="9c6143992817fbc2b5348e3563b07edf54283af4"
 Github ci latest is too old. Upgrade test with pg13 instead. References
 #5253 for PostGIS 3.4.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253#comment:7>
