[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-155-g15577bb2c
Sun Oct 2 03:55:40 PDT 2022
the project "PostGIS".
       via  15577bb2c255c174c80b6f7807bddd260cafbbc4 (commit)
      from  750c6dd7b8c71ae69d21a779a6a13c68cb03525a (commit)
revisions in full, below.
commit 15577bb2c255c174c80b6f7807bddd260cafbbc4
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 2 06:55:34 2022 -0400
    Add back latest but have test in upgrade mode
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 46d46ab2d..54a7879e7 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -27,12 +27,9 @@ jobs:
         - { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
         - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
-        # - { tag: latest, mode: tests }
+        - { tag: latest, mode: upgrade }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
         - { tag: pg12-geos37-gdal30-proj611, mode: tests }
-        # - { tag: pg11-geos37-gdal24-proj52, mode: tests }
-        # - { tag: pg10-geos36-gdal23-proj49, mode: tests }
-        # - { tag: pg96-geos36-gdal22-proj49, mode: tests }
     runs-on: ubuntu-latest
     steps:
diff --git a/ci/github/run_upgrade.sh b/ci/github/run_upgrade.sh
new file mode 100644
index 000000000..e30cd2519
--- /dev/null
+++ b/ci/github/run_upgrade.sh
@@ -0,0 +1,23 @@
+#!/usr/bin/env bash
+set -e
+WARNINGS="-Werror -Wall -Wextra -Wformat -Werror=format-security"
+WARNINGS_DISABLED="-Wno-unused-parameter -Wno-implicit-fallthrough -Wno-unknown-warning-option -Wno-cast-function-type"
+# Standard flags, as we might build PostGIS for production
+CFLAGS_STD="-g -O2 -mtune=generic -fno-omit-frame-pointer ${WARNINGS} ${WARNINGS_DISABLED}"
+LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
+export CUNIT_WITH_VALGRIND=YES
+export CUNIT_VALGRIND_FLAGS="--leak-check=full --error-exitcode=1"
+/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile -o '-F' start
+./autogen.sh
+# Standard build
+./configure CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}"
+#bash ./ci/github/logbt --
+make -j
+#bash ./ci/github/logbt \ --
+make install
+make check RUNTESTFLAGS="--verbose --extension -v --upgrade-path ${POSTGIS_MICRO_VER}--:auto!"
Summary of changes:
 .github/workflows/ci.yml                   | 5 +----
 ci/github/{run_tests.sh => run_upgrade.sh} | 3 ++-
 2 files changed, 3 insertions(+), 5 deletions(-)
 copy ci/github/{run_tests.sh => run_upgrade.sh} (87%)
hooks/post-receive
