[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-156-g34ddeb15f
Sun Oct 2 04:05:53 PDT 2022
the project "PostGIS".
       via  34ddeb15fc9b9c357b801f3773db787fa4a1e099 (commit)
      from  15577bb2c255c174c80b6f7807bddd260cafbbc4 (commit)
revisions in full, below.
commit 34ddeb15fc9b9c357b801f3773db787fa4a1e099
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 2 06:58:24 2022 -0400
    1) Oops forgot to declare from version.
    2) Add extension SELECT postgis_extensions_upgrade() to dronie
    Closes  #5253 for PostGIS 3.4.0dev
diff --git a/ci/github/run_upgrade.sh b/ci/github/run_upgrade.sh
index e30cd2519..47777940f 100644
--- a/ci/github/run_upgrade.sh
+++ b/ci/github/run_upgrade.sh
@@ -20,4 +20,9 @@ export CUNIT_VALGRIND_FLAGS="--leak-check=full --error-exitcode=1"
 make -j
 #bash ./ci/github/logbt \ --
 make install
+export POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+echo "Version ${POSTGIS_MICRO_VER}"
 make check RUNTESTFLAGS="--verbose --extension -v --upgrade-path ${POSTGIS_MICRO_VER}--:auto!"
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index bfcec355d..0d52bc51a 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -226,8 +226,22 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   done
-  # Check unpackaged->unpackaged upgrades
   CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
+  # Test current version to current version extension upgrade
+  do #{
+    UPGRADE_PATH="${CURRENTVERSION}--:auto!"
+    test_label="${EXT} extension-based upgrade ${UPGRADE_PATH}"
+    echo "Testing ${test_label}"
+    RUNTESTFLAGS="--extension -v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+    make -C ${REGDIR} check && {
+      echo "PASS: ${test_label}"
+      echo "FAIL: ${test_label}"
+      failed
+  done #}
+  # Check unpackaged->unpackaged upgrades
   if test "${to_version}" = "${CURRENTVERSION}"; then
     for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`
     do #{
Summary of changes:
 ci/github/run_upgrade.sh    |  5 +++++
 utils/check_all_upgrades.sh | 16 +++++++++++++++-
 2 files changed, 20 insertions(+), 1 deletion(-)
hooks/post-receive
