[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-158-gef5214359
Sun Oct 2 04:15:27 PDT 2022
the project "PostGIS".
       via  ef5214359ad2033eea7cc6ff043c57886975cc82 (commit)
       via  9c6143992817fbc2b5348e3563b07edf54283af4 (commit)
      from  34ddeb15fc9b9c357b801f3773db787fa4a1e099 (commit)
revisions in full, below.
commit ef5214359ad2033eea7cc6ff043c57886975cc82
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 2 07:15:22 2022 -0400
    Put back msys, see if it works now
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 74e43b15c..b92c443a9 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -4,7 +4,8 @@ on: [push, pull_request]
 jobs:
   mingw:
     # TODO: check to see if we need to disable again
-    if: github.repository == 'master'
+    #if: github.repository == 'master'
+    if: true
     runs-on: windows-latest
     strategy:
commit 9c6143992817fbc2b5348e3563b07edf54283af4
Date:   Sun Oct 2 07:14:22 2022 -0400
    Github ci latest is too old. Upgrade test with pg13 instead. References #5253 for PostGIS 3.4.0dev
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 54a7879e7..79b639b59 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -27,8 +27,8 @@ jobs:
         - { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
         - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
-        - { tag: latest, mode: upgrade }
-        - { tag: pg13-geos38-gdal31-proj71, mode: tests }
+        # - { tag: latest, mode: upgrade }
+        - { tag: pg13-geos38-gdal31-proj71, mode: upgrade }
         - { tag: pg12-geos37-gdal30-proj611, mode: tests }
     runs-on: ubuntu-latest
Summary of changes:
 .github/workflows/ci.yml   | 4 ++--
 .github/workflows/msys.yml | 3 ++-
 2 files changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
