[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.1-12-ga0e206a9d
Sun Oct 2 13:56:20 PDT 2022
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  a0e206a9d956d488a30126b019cc91a156977e7d (commit)
       via  5312e0b21e9301fcd88f67440fa1e151c58ad1a9 (commit)
       via  93b98069713d46282cd23c3bedec6fc82242a513 (commit)
       via  98070faad220e12fcaed9a583a70a37c510b7c6b (commit)
      from  c0e66c7af3791452c2da09506204949945fbc063 (commit)
revisions in full, below.
commit a0e206a9d956d488a30126b019cc91a156977e7d
Merge: 5312e0b21 93b980697
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 2 16:51:52 2022 -0400
    Merge remote-tracking branch 'tpetazzoni/no-force-static-link' into stable-3.3
    References #5255 for PostGIS 3.3.2 , GH702
    Remove forced static linking on raster2pgsql (Thomas Petazzoni)
diff --cc NEWS
index 1c7dc317c,e77dfc2c9..a03745906
--- a/NEWS
+++ b/NEWS
@@@ -1,109 -1,5 +1,110 @@@
 +PostGIS 3.3.2
 +xxxx/xx/xx
 +* Bug Fix *
 +  - #5248, Marc21 documentation missing (Regina Obe)
 +  - #5420, ST_DumpPoints and ST_DumpSegments crash with empty polygon (Regina Obe)
 +  - Add schema qual to upgrade util (Regina Obe)
 +  - #5255, GH598, Remove forced static linking on shp2pgsql, pgsql2shp (Maxim Kochetkov)
++  - #5255, GH702, Remove forced static linking on raster2pgsql (Thomas Petazzoni)
 +PostGIS 3.3.1
 +2022/09/09
 + * Bug Fix *
 +  - #5227, typo in ST_LineLocatePoint error message (Sandro Santilli)
 +  - #5231, PG15 no longer compiles because SQL/JSON removed PG upstream (Regina Obe)
 +PostGIS 3.3.0
 +2022/08/26
 +This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
 +Additional features are enabled if you are running GEOS 3.9+
 +ST_MakeValid enhancements with 3.10+, ST_ConcaveHull and several other enhancements with GEOS 3.11+.
 +Requires SFCGAL 1.4.1+ for ST_AlphaShape and ST_OptimalAlphaShape.
 +The new --enable-lto flag improves math computations.  This new feature is disabled by default
 +because on some platforms, causes compilation errors (BSD and MingW64 issues have been raised)
 +Use below to enable it.
 + ./configure --enable-lto flag
 + * New features *
 +  - #5116, Topology export/import scripts (Sandro Santilli)
 +  - ST_Letters creates geometries that look like letters (Paul Ramsey)
 +  - #5037, postgis_sfcgal: ST_3DConvexHull (Loïc Bartoletti)
 +  - postgis_sfcgal: sfcgal_full_version - reports BOOST and CGAL version
 +    (Loïc Bartoletti)
 +  - GH659, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)
 +  - #5132, GH683, sfcgal: ST_3DUnion aggregate function (Sergei Shoulbakov)
 +  - #5143, SFCGAL ST_AlphaShape and ST_OptimalAlphaShape
 +           Requires SFCGAL 1.4.1+ (Loïc Bartoletti)
 +  - #5162, ST_TriangulatePolygon with GEOS 3.11+ (Paul Ramsey, Martin Davis)
 +  - #5162, ST_SimplifyPolygonHull with GEOS 3.11+ (Paul Ramsey, Martin Davis)
 +  - #5183, topology.RemoveUnusedPrimitives (Sandro Santilli)
 + * Breaking changes *
 +  - Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
 +  - Change output for WKT MULTIPOINT. All points now
 +    wrapped in parens. (Even Roualt)
 +  - GH674, geometry validation and fixing is disabled
 +    for ST_DumpAsPolygons and ST_Polygon so it works faster
 +    but might produce invalid polygons. (Aliaksandr Kalenik)
 + * Enhancements *
 +  - #2861, Add index on topology.node(containing_face) speeding up
 +    splitting and merging of faces (Sandro Santilli)
 +  - #2083, Speed up ST_RemEdge topology functions adding index on
 +    relation(element_id) and edge_data(abs_next*) (Sandro Santilli)
 +  - #5118, Allow dropping topologies with missing topogeometry sequences
 +    (Sandro Santilli)
 +  - #5111, faster topology face MBR computation (Sandro Santilli)
 +  - postgis_extensions_upgrade() support for upgrades from any PostGIS
 +    version, including yet to be released ones (Sandro Santilli)
 +  - #5040, add postgis_sfcgal_full_version (Loïc Bartoletti)
 +  - GH655, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)
 +  - GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
 +  - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
 +    useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
 +  - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
 +  - ST_ConcaveHull GEOS 3.11+ polygon-respecting native implementation (Paul Ramsey, Martin Davis)
 +  - #4574, GH678, #5121 Enable Link-Time Optimizations using --enable-lto (Sergei Shoulbakov)
 +  - GH676, faster ST_Clip (Aliaksandr Kalenik)
 +  - #5135, Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
 +  - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
 +  - #5170, add a optional max_rows_per_copy to -Y option to raster2pgsql to
 +    control number of rows per copy statement.
 +    Default to 50 when not specified (Regina Obe)
 +  - GH698, support parallel aggregate for ST_Union (Sergei Shoulbakov)
 +  - #5024, Update spatial_ref_sys as part of ALTER EXTENSION update postgis (Paul Ramsey)
 + * Bug Fix *
 +   These are fixes not backported to older minors
 +   - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
 +   - #5088, Memory corruption in mvt_agg_transfn (Victor Collod)
 +   - #5137, resetting interrupt flags before query execution (Sergei Shoulbakov)
 +   - #5148, ST_Clip is more robust to alignment of raster and clip geometry (Sergei Shoulbakov)
 +   - #4932, Bug with geography ST_Intersects / ST_Distance (Paul Ramsey)
 +   - #5089, ST_Reverse also reverses components of CompoundCurve (Paul Ramsey)
 +PostGIS 3.3.0rc2
 +2022/08/21
 +ST_MakeValid enhancements with 3.10+, numerouse additional enhancements with GEOS 3.11+.
 +  - #5181, Reset proj error state after failed parse (Paul Ramsey)
 +  - #5171, Short circuit geodesic distance when inputs equal (Paul Ramsey)
  PostGIS 3.3.0rc1
 -2022/xx/xx
 +2022/08/08
commit 5312e0b21e9301fcd88f67440fa1e151c58ad1a9
Merge: c0e66c7af 98070faad
Date:   Sun Oct 2 16:43:36 2022 -0400
    Merge remote-tracking branch 'fidomax/patch-4' into stable-3.3
    Remove force static linking of postgis command line tools
    References GH598
    Contribution from Maxim Kochetkov
diff --cc NEWS
index c15c587de,ed9584b33..1c7dc317c
--- a/NEWS
+++ b/NEWS
@@@ -1,415 -1,5 +1,416 @@@
 -PostGIS 3.2.0
 -2021/xx/xx
 +PostGIS 3.3.2
 +xxxx/xx/xx
 +* Bug Fix *
++  - #5255, GH598, Remove forced static linking on shp2pgsql, pgsql2shp (Maxim Kochetkov)
 +PostGIS 3.3.1
 +2022/09/09
 + * Bug Fix *
 +PostGIS 3.3.0
 +2022/08/26
 + * New features *
 +    (Loïc Bartoletti)
 + * Enhancements *
 +    (Sandro Santilli)
 + * Bug Fix *
 +PostGIS 3.3.0rc2
 +2022/08/21
 +PostGIS 3.3.0rc1
 +2022/08/08
 +Changes since PostGIS 3.3.0beta2:
 +* Bug fixes *
 +  - #5154, raster ST_Value is undercosted (Regina Obe)
 +  - #5157, Revise minimum_bounding_circle Cunit test
 +           to be tolerant of small 32-bit floating point differences
 +           (Regina Obe)
 +  - #5191, Functions should use integer instead of int4 (Regina Obe)
 +  - #5139, PostGIS causes to_jsonb to no longer be parallel safe,
 +           ST_AsGeoJSON and ST_AsGML are also parallel unsafe
 +           (Regina Obe, Paul Ramsey)
 +  - #5025, Ensure that additional operators are not appended
 +           when the function and opfamily disagree
 +           about dimensionality (Paul Ramsey)
 +  - #5195, #5196  Change address_standardizer
 +           and postgis_tiger_geocoder CREATE EXTENSION to use CREATE
 +           instead of CREATE OR REPLACE. (Regina Obe)
 +  - #5202, Guard against downgrade (Sandro Santilli)
 +  - #5104, postgis_extensions_upgrade() fails with pgextwlist (Regina Obe)
 +PostGIS 3.3.0beta2
 +2022/07/13
 +Changes since PostGIS 3.3.0beta1
 +* New features *
 +* Enhancements *
 +* Bug fixes *
 +  - #5179, pgsql2shp syntax error on big-endian (Bas Couwenberg)
 +PostGIS 3.3.0beta1
 +2022/07/03
 +NOTE: GEOS 3.11.0 was recently released,
 + details at https://libgeos.org/posts/2022-07-01-geos-3-11-0-released/.
 +Changes since PostGIS 3.3.0alpha1
 +* Enhancements *
 +  - #5039, postgis_tiger_geocoder TIGER 2021 (Regina Obe)
 +* New features *
 +  - #5169, ST_SimplifyPolygonHull (requires GEOS 3.11)
 +* Bug fixes *
 +  - #5173 st_asflatgeobuf detoast crash (Paul Ramsey)
 +  - #5114, pgsql2shp segfault with long or many truncated columns
 +PostGIS 3.3.0alpha1
 +2022/05/21
 +ST_MakeValid enhancements with 3.10+, ST_ConcaveHull enhancements with GEOS 3.11+.
 +NOTE: GEOS 3.11+ is not yet released, you can download from https://github.com/libgeos/geos.
 +PostGIS 3.2.0 (Olivier Courtin Edition)
 +2021/12/17
 +This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+.
 +(and ST_MakeValid enhancements with 3.10+),
 +Proj 6.1+, and PostgreSQL 14+.
 +Due to some query performance degradation
 +with the new fast index build that requires PG14,
 +we have decided to disable the feature by default
 +until we get more user testing
 +as to the true impact of real-world queries.
 +If you are running PG14+, you can reenable it by doing
 +ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
 +     ADD FUNCTION 11 (geometry)
 +     geometry_gist_sortsupport_2d (internal);
 +and then reindex your gist indexes.
 +To revert back to the old index behavior:
 +   ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
 +     DROP FUNCTION 11 (geometry);
 +  - #5008, Empty geometries are not reported as being within Infinite
 +           distance by ST_DWithin (Sandro Santilli)
 +  - #4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.
 +  - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
 +  - #4981, ST_StartPoint support any geometry. No longer returns null for non-linestrings.
 +  - #4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
 +           If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
 +           (Darafei Praliaskouski)
 +  - Proj 4.9 or higher is required
 +  - #5000, Turn off Window support in ST_AsMVT aggregate
 +        as no real use-case for it and it crashes with random input
 +        (Paul Ramsey)
 + * Enhancements *
 +  - #4997, FlatGeobuf format input/output (Björn Harrtell)
 +  - #4575, GRANT SELECT on topology metadata tables to PUBLIC (Sandro Santilli)
 +  - #2592, Do not allow CreateTopology to define topologies with SRID < 0
 +           (Sandro Santilli)
 +  - #3232, Prevent moving an isolated node to different face
 +           (Sandro Santilli)
 +  - Consider collection TopoGeometries while editing topology primitives.
 +           (Sandro Santilli)
 +  - #3248, Prevent removing isolated edges if used in a TopoGeometry
 +           (Sandro Santilli)
 +  - #3231, Prevent removing isolated nodes if used in a TopoGeometry
 +           (Sandro Santilli)
 +  - #3239, Prevent headling topology edges if the connecting node is
 +           used in the definition of a TopoGeometry (Sandro Santilli)
 +  - #4950, Speed up checking containing_face for nodes in ValidateTopology
 +           (Sandro Santilli)
 +  - #4945, Multi-shell face check in ValidateTopology (Sandro Santilli)
 +  - #4944, Side-location conflict check in ValidateTopology (Sandro Santilli)
 +  - #3042, ValidateTopology check for edge linking (Sandro Santilli)
 +  - #3276, ValidateTopology check for face's mbr (Sandro Santilli)
 +  - #4936, Bounding box limited ValidateTopology (Sandro Santilli)
 +  - #4933, Speed up topology building in presence of big faces (Sandro Santilli)
 +  - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
 +  - #4830, ValidateTopology check for edges side face containment
 +           (Sandro Santilli)
 +  - #4827, Allow NaN coordinates in WKT input (Paul Ramsey)
 +  - ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)
 +  - #3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)
 +  - #4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
 +           to retain direction (Sandro Santilli)
 +  - #4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)
 +  - #4924, Faster ST_RemoveRepeatedPoints on large multipoints, O(NlogN) instead of O(N^2)
 +           (Aliaksandr Kalenik, Darafei Praliaskouski)
 +  - #4925, fix ST_DumpPoints to not overlook points (Aliaksandr Kalenik)
 +  - ST_SRID(topogeometry) override, to speedup lookups (Sandro Santilli)
 +  - #2175, Avoid creating additional nodes when adding same closed
 +           line to topology (Sandro Santilli)
 +  - #4974, Upgrade path for address_standardizer_data_us
 +           (Jan Katins of Aiven, Regina Obe)
 +  - #4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)
 +  - #4981, ST_StartPoint support any geometry (Aliaksandr Kalenik)
 +  - #4799, Include srs in GeoJSON where it exists in spatial_ref_sys.
 +  - #4986, GIST indexes on Postgres 14 are now created faster using Hilbert-sorting method.
 +           (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)
 +  - #4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)
 +  - GH647, ST_PixelAsCentroids, ST_PixelAsCentroid reimplemented on top of a C function (Sergei Shoulbakov)
 +  - GH648, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
 +  - #5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)
 +  - #5019, address_standardizer: Add support for pcre2 (Paul Ramsey)
 + * New features*
 +  - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
 +  - #4933, topology.GetFaceContainingPoint (Sandro Santilli)
 +  - #2175, ST_Scroll (Sandro Santilli)
 +  - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
 +  - #4869, FindLayer to quickly get a layer record (Sandro Santilli)
 +  - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
 +  - ST_MakeValid(geometry, options) allows alternative validity building
 +    algorithms with GEOS 3.10 (Paul Ramsey)
 +  - ST_InterpolateRaster() fills in raster cells between sample points
 +    using one of a number of algorithms (inverse weighted distance, average, etc)
 +    using algorithms from GDAL
 +    (Paul Ramsey)
 +  - ST_Contour() generates contour lines from raster values
 +    using algorithms from GDAL (Paul Ramsey)
 +  - ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
 +    from a raster (Paul Ramsey)
 +  - New postgis.gdal_vsi_options GUC allows out-db rasters on VSI network
 +    services to be accessed with authentication keys, etc. (Paul Ramsey)
 +  - ST_DumpSegments returns a set of segments of input geometry (Aliaksandr Kalenik)
 +  - #4859, ST_Point, ST_PointZ, ST_PointM, ST_PointZM, constructors
 +    with SRID parameter (Paul Ramsey)
 +  - #4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
 +    the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)
 +PostGIS 3.2.0beta3
 +2021/12/04
 +To revert the change:
 +Changes since PostGIS 3.2.0beta2 release:
 +  * Breaking changes / fixes *
 +  - #5028, ST_AsFlatGeobuf crashes on mixed geometry input
 +    (Björn Harrtell)
 +  - #5029, ST_AsFlatGeobuf indexed output corruption
 +    (Björn Harrtell)
 +  - #5014, Crash on ST_TableFromFlatGeobuf (Björn Harrtell)
 +  - Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
 +    (Björn Harrtell)
 +  - PG14 fast index building disabled by default. (Paul Ramsey)
 +PostGIS 3.2.0beta2
 +2021/11/26
 +Changes since PostGIS 3.2.0beta1 release:
 +  - #5016, loader (shp2pgsql): Respect LDFLAGS (Greg Troxel)
 +  - #5005, ST_AsFlatGeoBuf crashes on tables when geometry
 +           column is not the first column (Björn Harrtell)
 +  - #5017, topology.ValidateTopology error relation "shell_check"
 +           already exists (Sandro Santilli)
 +  * Enhancements *
 +  - GH647, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
 +  - GH648, ST_PixelAsCentroids, ST_PixelAsCentroid
 +           reimplemented in C (Sergei Shoulbakov)
 +PostGIS 3.2.0beta1
 +2021/10/23
 +Changes since PostGIS 3.2.0alpa1 release:
 +  * Bug Fixes and Breaking Changes *
 +    - #5012, Clean regress against released GEOS 3.10.0
 +        (Paul Ramsey)
 +    - #4994, shp2pgsql is sometimes missing the INSERT statements
 +      (Sandro Santilli)
 +    - #4990, getfacecontainingpoint fails on i386 (Sandro Santilli)
 +    - #5008, Have ST_DWithin with EMPTY operand always return false
 +      (Sandro Santilli)
 +    - #5002, liblwgeom should build with warning flags by default
 +      (Sandro Santilli)
 +  * Enhancements *
 +PostGIS 3.2.0alpha1
 +2021/09/10
 +Additional features are enabled if you are running GEOS 3.9+, Proj 6.1+, and PostgreSQL 14+.
Summary of changes:
 NEWS                      | 2 ++
 loader/Makefile.in        | 2 +-
 raster/loader/Makefile.in | 2 +-
 3 files changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
