[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.3-14-gebab0be6a
    git at osgeo.org
    git at osgeo.org
    Sun Oct  2 23:16:52 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  ebab0be6a6ae1e9d4b50f96a95f3f35d61ab0e94 (commit)
       via  7c8c14b26e8b38c1dbcc0a517e8b4c1e01596b63 (commit)
       via  98070faad220e12fcaed9a583a70a37c510b7c6b (commit)
      from  e62bf6eb7555b180319abee86245b5c94e4d2ea8 (commit)
revisions in full, below.
commit ebab0be6a6ae1e9d4b50f96a95f3f35d61ab0e94
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Oct 3 02:15:13 2022 -0400
    ReImove forced static linking on raster2pgsql (Thomas Petazzoni)
    References #5255 for PostGIS 3.2.4
    Referebces https://github.com/postgis/postgis/pull/702 for PostGIS 3.2.4
diff --git a/NEWS b/NEWS
index bc53e1858..6f1e95bfe 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ PostGIS 3.2.4
   - #5420, ST_DumpPoints and ST_DumpSegments crash with empty polygon (Regina Obe)
   - Add schema qual to upgrade util
   - #5255, GH598, Remove forced static linking on shp2pgsql, pgsql2shp (Maxim Kochetkov)
+  - #5255, GH702, Remove forced static linking on raster2pgsql (Thomas Petazzoni)
 PostGIS 3.2.3
diff --git a/raster/loader/Makefile.in b/raster/loader/Makefile.in
index 3df47a96f..d0a408333 100644
--- a/raster/loader/Makefile.in
+++ b/raster/loader/Makefile.in
@@ -36,7 +36,7 @@ PGSQL_BINDIR=@PGSQL_BINDIR@
 RT_CORE=../rt_core
-LIBLWGEOM_LDFLAGS= -static ../../liblwgeom/liblwgeom.la
+LIBLWGEOM_LDFLAGS= ../../liblwgeom/liblwgeom.la
 LIBLWGEOM_CFLAGS=-I../../liblwgeom
 LIBGDAL_CFLAGS=@LIBGDAL_CFLAGS@
 LIBGDAL_LDFLAGS=@LIBGDAL_LDFLAGS@
commit 7c8c14b26e8b38c1dbcc0a517e8b4c1e01596b63
Merge: e62bf6eb7 98070faad
Date:   Mon Oct 3 01:53:17 2022 -0400
    Merge remote-tracking branch 'fidomax/patch-4' into stable-3.2
    References https://github.com/postgis/postgis/pull/598 for PostGIS 3.2.4
diff --cc NEWS
index da8f2f5fb,ed9584b33..bc53e1858
--- a/NEWS
+++ b/NEWS
@@@ -1,290 -1,5 +1,292 @@@
 -PostGIS 3.2.0
 -2021/xx/xx
 +PostGIS 3.2.4
- 2022/09/xx
++2022/xx/xx
 +* Bug Fixes *
 +  - #5227, typo in ST_LineLocatePoint error message (Sandro Santilli)
 +  - #5231, PG15 no longer compiles because SQL/JSON removed PG upstream (Regina Obe)
 +  - #5420, ST_DumpPoints and ST_DumpSegments crash with empty polygon (Regina Obe)
 +  - Add schema qual to upgrade util
++  - #5255, GH598, Remove forced static linking on shp2pgsql, pgsql2shp (Maxim Kochetkov)
 +PostGIS 3.2.3
 +2022/08/18
 +This version requires PostgreSQL 9.6-15, GEOS 3.6 or higher, and Proj 4.9+
 +Additional features are enabled if you are running GEOS 3.9+
 + (and ST_MakeValid enhancements with 3.10+),
 +Proj 6.1+, and PostgreSQL 14+.
 +* Bug Fixes *
 +  - #5191, Use integer instead of int4 (Regina Obe)
 +  - #5139, PostGIS causes to_jsonb to no longer be parallel safe,
 +           ST_AsGeoJSON and ST_AsGML are also parallel unsafe
 +           (Regina Obe, Paul Ramsey)
 +  - #5202, Guard against downgrades (Sandro Santilli)
 +  - #5209, #5210, Fix upgrades with CVE-2022-2625 PostgreSQL fix
 +  - #5032, Correctly read extent off multi-key GIST indexes (Paul Ramsey)
 +  - #5181, Reset proj error state after failed parse (Paul Ramsey)
 +  - #5171, Short circuit geodesic distance when inputs equal (Paul Ramsey)
 +  - Fix potential buffer overflow in long transaction locks (Paul Ramsey)
 +PostGIS 3.2.2
 +2022/07/22
 +* Bug Fixes *
 +  - #5182, Fix loading topology.sql in new database (Sandro Santilli)
 +  - #4835, Occasional distance errors in polar area (Paul Ramsey)
 +  - #5124, GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
 +  - #5120, Fix not-null result from ST_EstimatedExtent against
 +           truncated tables with spatial index (Sandro Santilli)
 +  - #5115, Allow dropping topologies with pending constraints
 +           (Sandro Santilli)
 +  - #5105, Fix false invalidity report from ValidateTopology
 +           (Sandro Santilli)
 +  - #5039, postgis_tiger_geocoder: Support for TIGER 2021 (Regina Obe)
 +  - #5097, Ensure spatial index is used during topology population
 +           at the getClosestEdge step (Sandro Santilli)
 +  - #5091, Fix --without-protobuf builds (Tobias Bussmann)
 +  - #5100, Don't use pg_atoi (removed in PG15) (Laurenz Albe)
 +  - #5114, Crash with long column names pgsql2shp (Paul Ramsey)
 +  - #5123, Support for PG15 (JSON funcs exposed) (Regina Obe)
 +  - #5125, Fix search path function (Sandro Santilli)
 +  - #5150, Change signature of AddToSearchPath (Regina Obe)
 +  - #5151, ST_SetPoint with empty geometries (Regina Obe)
 +  - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
 +  - #5173, Crash creating flatgeobuf on row without geometry (Julien Rouhaud)
 +  - #4541, ST_ConcaveHull returns a "geometrycollection" type instead of the expected "polygon"
 +- - #5154, raster ST_Value is undercosted (Regina Obe)
 +PostGIS 3.2.1
 +2022/02/12
 +* Bug Fixes *
 +  - #5033, #5035, allow upgrades in presence of views using deprecated
 +           functions (Sandro Santilli)
 +  - #5046, Fix upgrades in absence of old library (Sandro Santilli)
 +  - #5063, Fix ST_Srid(TopoGeometry) against a set (Sandro Santilli)
 +  - #3056, spurious notice on ST_StartPoint(empty) (Paul Ramsey)
 +  - #5041, postgis_tiger_geocoder: loader_generate_script
 +           generates script with invalid syntax (Regna Obe)
 +  - #5076, stop install when pgaudit is active (Paul Ramsey)
 +  - #5069, search_path vulnerabilty during install/upgrade
 +           (Regina Obe)
 +  - #5090, #5091 configure --with-protobuf-lib / --with-protobufdir
 +           , --without-protobuf broken (Tobias Bussmann)
 +PostGIS 3.2.0 (Olivier Courtin Edition)
 +2021/12/17
 +This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher
 +, and Proj 4.9+.
 +(and ST_MakeValid enhancements with 3.10+),
 +Due to some query performance degradation
 +with the new fast index build that requires PG14,
 +we have decided to disable the feature by default
 +until we get more user testing
 +as to the true impact of real-world queries.
 +If you are running PG14+, you can reenable it by doing
 +ALTER OPERATOR FAMILY gist_geometry_ops_2d USING gist
 +     ADD FUNCTION 11 (geometry)
 +     geometry_gist_sortsupport_2d (internal);
 +and then reindex your gist indexes.
 +To revert back to the old index behavior:
 +   ALTER OPERATOR FAMILY gist_geometry_ops_2d using gist
 +     DROP FUNCTION 11 (geometry);
 + * Breaking changes *
 +  - #5008, Empty geometries are not reported as being within Infinite
 +           distance by ST_DWithin (Sandro Santilli)
 +  - #4824, Removed `--without-wagyu` build option. Using Wagyu is now mandatory to build with MVT support.
 +  - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
 +  - #4981, ST_StartPoint support any geometry. No longer returns null for non-linestrings.
 +  - #4149, ST_AsMVTGeom now preserves more of original geometry's details at scale close to target extent.
 +           If you need previous simplifying behaviour, you can ST_Simplify the geometry in advance.
 +           (Darafei Praliaskouski)
 +  - Proj 4.9 or higher is required
 +  - #5000, Turn off Window support in ST_AsMVT aggregate
 +        as no real use-case for it and it crashes with random input
 +        (Paul Ramsey)
 + * Enhancements *
 +  - #4997, FlatGeobuf format input/output (Björn Harrtell)
 +  - #4575, GRANT SELECT on topology metadata tables to PUBLIC (Sandro Santilli)
 +  - #2592, Do not allow CreateTopology to define topologies with SRID < 0
 +           (Sandro Santilli)
 +  - #3232, Prevent moving an isolated node to different face
 +           (Sandro Santilli)
 +  - Consider collection TopoGeometries while editing topology primitives.
 +           (Sandro Santilli)
 +  - #3248, Prevent removing isolated edges if used in a TopoGeometry
 +           (Sandro Santilli)
 +  - #3231, Prevent removing isolated nodes if used in a TopoGeometry
 +           (Sandro Santilli)
 +  - #3239, Prevent headling topology edges if the connecting node is
 +           used in the definition of a TopoGeometry (Sandro Santilli)
 +  - #4950, Speed up checking containing_face for nodes in ValidateTopology
 +           (Sandro Santilli)
 +  - #4945, Multi-shell face check in ValidateTopology (Sandro Santilli)
 +  - #4944, Side-location conflict check in ValidateTopology (Sandro Santilli)
 +  - #3042, ValidateTopology check for edge linking (Sandro Santilli)
 +  - #3276, ValidateTopology check for face's mbr (Sandro Santilli)
 +  - #4936, Bounding box limited ValidateTopology (Sandro Santilli)
 +  - #4933, Speed up topology building in presence of big faces (Sandro Santilli)
 +  - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
 +  - #4830, ValidateTopology check for edges side face containment
 +           (Sandro Santilli)
 +  - #4827, Allow NaN coordinates in WKT input (Paul Ramsey)
 +  - ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)
 +  - #3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)
 +  - #4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
 +           to retain direction (Sandro Santilli)
 +  - #4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)
 +  - #4924, Faster ST_RemoveRepeatedPoints on large multipoints, O(NlogN) instead of O(N^2)
 +           (Aliaksandr Kalenik, Darafei Praliaskouski)
 +  - #4925, fix ST_DumpPoints to not overlook points (Aliaksandr Kalenik)
 +  - ST_SRID(topogeometry) override, to speedup lookups (Sandro Santilli)
 +  - #2175, Avoid creating additional nodes when adding same closed
 +           line to topology (Sandro Santilli)
 +  - #4974, Upgrade path for address_standardizer_data_us
 +           (Jan Katins of Aiven, Regina Obe)
 +  - #4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)
 +  - #4981, ST_StartPoint support any geometry (Aliaksandr Kalenik)
 +  - #4799, Include srs in GeoJSON where it exists in spatial_ref_sys.
 +  - #4986, GIST indexes on Postgres 14 are now created faster using Hilbert-sorting method.
 +           (Han Wang, Aliaksandr Kalenik, Darafei Praliaskouski, Giuseppe Broccolo)
 +  - #4949, Use proj_normalize_for_visualization to hand "axis swap" decisions (Paul Ramsey)
 +  - GH647, ST_PixelAsCentroids, ST_PixelAsCentroid reimplemented on top of a C function (Sergei Shoulbakov)
 +  - GH648, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
 +  - #5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)
 +  - #5019, address_standardizer: Add support for pcre2 (Paul Ramsey)
 + * New features*
 +  - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
 +  - #4933, topology.GetFaceContainingPoint (Sandro Santilli)
 +  - #2175, ST_Scroll (Sandro Santilli)
 +  - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
 +  - #4869, FindLayer to quickly get a layer record (Sandro Santilli)
 +  - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
 +  - ST_MakeValid(geometry, options) allows alternative validity building
 +    algorithms with GEOS 3.10 (Paul Ramsey)
 +  - ST_InterpolateRaster() fills in raster cells between sample points
 +    using one of a number of algorithms (inverse weighted distance, average, etc)
 +    using algorithms from GDAL
 +    (Paul Ramsey)
 +  - ST_Contour() generates contour lines from raster values
 +    using algorithms from GDAL (Paul Ramsey)
 +  - ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
 +    from a raster (Paul Ramsey)
 +  - New postgis.gdal_vsi_options GUC allows out-db rasters on VSI network
 +    services to be accessed with authentication keys, etc. (Paul Ramsey)
 +  - ST_DumpSegments returns a set of segments of input geometry (Aliaksandr Kalenik)
 +  - #4859, ST_Point, ST_PointZ, ST_PointM, ST_PointZM, constructors
 +    with SRID parameter (Paul Ramsey)
 +  - #4808, ST_ClusterKMeans now supports max_radius argument. Use it when you're not sure what is
 +    the number of clusters but you know what the size of clusters should be. (Darafei Praliaskouski)
 +PostGIS 3.2.0beta3
 +2021/12/04
 +This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher, and Proj 4.9+
 +To revert the change:
 +Changes since PostGIS 3.2.0beta2 release:
 +  * Breaking changes / fixes *
 +  - #5028, ST_AsFlatGeobuf crashes on mixed geometry input
 +    (Björn Harrtell)
 +  - #5029, ST_AsFlatGeobuf indexed output corruption
 +    (Björn Harrtell)
 +  - #5014, Crash on ST_TableFromFlatGeobuf (Björn Harrtell)
 +  - Rename ST_TableFromFlatGeobuf to ST_FromFlatGeobufToTable
 +    (Björn Harrtell)
 +  - PG14 fast index building disabled by default. (Paul Ramsey)
 +PostGIS 3.2.0beta2
 +2021/11/26
 +Changes since PostGIS 3.2.0beta1 release:
 +  - #5016, loader (shp2pgsql): Respect LDFLAGS (Greg Troxel)
 +  - #5005, ST_AsFlatGeoBuf crashes on tables when geometry
 +           column is not the first column (Björn Harrtell)
 +  - #5017, topology.ValidateTopology error relation "shell_check"
 +           already exists (Sandro Santilli)
 +  * Enhancements *
 +  - GH647, ST_AsMVTGeom now uses faster clipping (Aliaksandr Kalenik)
 +  - GH648, ST_PixelAsCentroids, ST_PixelAsCentroid
 +           reimplemented in C (Sergei Shoulbakov)
 +PostGIS 3.2.0beta1
 +2021/10/23
 +Changes since PostGIS 3.2.0alpa1 release:
 +  * Bug Fixes and Breaking Changes *
 +    - #5012, Clean regress against released GEOS 3.10.0
 +        (Paul Ramsey)
 +    - #4994, shp2pgsql is sometimes missing the INSERT statements
 +      (Sandro Santilli)
 +    - #4990, getfacecontainingpoint fails on i386 (Sandro Santilli)
 +    - #5008, Have ST_DWithin with EMPTY operand always return false
 +      (Sandro Santilli)
 +    - #5002, liblwgeom should build with warning flags by default
 +      (Sandro Santilli)
 +  * Enhancements *
 +PostGIS 3.2.0alpha1
 +2021/09/10
 +Additional features are enabled if you are running GEOS 3.9+, Proj 6.1+, and PostgreSQL 14+.
Summary of changes:
 NEWS                      | 5 ++++-
 loader/Makefile.in        | 2 +-
 raster/loader/Makefile.in | 2 +-
 3 files changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
