[postgis-tickets] [PostGIS] #5256: check_all_upgrades.sh does not test postgis_extensions_upgrade from same version to same version
trac at osgeo.org
Mon Oct 3 17:43:09 PDT 2022
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.0
Component: build/upgrade/install | Version: master
Keywords: |
As noted in #5253, none of the ci bots showed red for the error #5253.
I only stumbled on the issue when trying to upgrade my dev environment.
To fix I had put in a test specifically for current -- auto!
[b9439d2d0d7/git]
strk thinks this should not have been needed. I had a hard time reading
this script so I may have missed where it is called.
My understanding is --auto uses the standard extension machinery
--auto! uses the postgis_extensions_upgrade() function
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5256>
