[postgis-tickets] [PostGIS] #5256: check_all_upgrades.sh does not test postgis_extensions_upgrade from same version to same version
PostGIS trac at osgeo.org
Tue Oct 4 07:13:22 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 The `check_all_ugprades.sh` script never tested self-self upgrade because
 `make` targets should be doing that already, specifically:
    - `make check` should be testing with --upgrade which does script-based
 upgrade
    - `make installcheck` should be testing with --extension from
 unpackaged, both via DDL and via postgis_extension_upgrade [ see `make
 installcheck-upgrade-byfunc` ]
 From what I can see gitlab-ci is supposed to be running `make
 installcheck` so should do the same-same upgrade.
 Which path are we missing, exactly ? Same-same both being extension ?
 Better be specific about the *problem* (renaming this ticket to indicate
 the problem)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5256#comment:1>
