[postgis-tickets] [PostGIS] #5256: "3.4.0dev--:auto!" upgrade test not performed by bots (was: check_all_upgrades.sh does not test postgis_extensions_upgrade from same version to same version)
PostGIS trac at osgeo.org
Tue Oct 4 07:15:26 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * summary:
     => "3.4.0dev--:auto!" upgrade test not performed by bots
Comment:
 Ok I renamed the ticket to `"3.4.0dev--:auto!" upgrade test not performed
 by bots` as that's what  I understand is happening.
 I think we should have `make installcheck` run that test, as it currently
 only tests the upgrade from _unpackaged_ and not from self-extension.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5256#comment:2>
