[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-167-g44d725332
Tue Oct 4 15:52:27 PDT 2022
the project "PostGIS".
       via  44d72533269d4729b4f2e2474ed4e503b5ddce4b (commit)
      from  f72f7e431c195a71f262db0f728e4c21a4295aec (commit)
revisions in full, below.
commit 44d72533269d4729b4f2e2474ed4e503b5ddce4b
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 5 00:10:16 2022 +0200
    Enhance make installcheck to include self-self by-function upgrade
    Drop hard-coded by-function upgrade test from check_all_upgrades.sh
    landed with 34ddeb15fc9b9c357b801f3773db787fa4a1e099
    Closes #5256
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 50c2313ac..9d29597af 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -14,6 +14,7 @@ HAVE_SFCGAL=@HAVE_SFCGAL@
 POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
 POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
 POSTGIS_MICRO_VERSION=@POSTGIS_MICRO_VERSION@
+POSTGIS_FULL_VERSION=$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)
 PERL = @PERL@
 top_srcdir = @top_srcdir@
@@ -68,23 +69,36 @@ check-no-trailing-blanks:
 installcheck: installcheck-base installcheck-upgrade
 installcheck-base:
+	# this includes packaged-extension self upgrade
 	$(MAKE) check-regress RUNTESTFLAGS="$(RUNTESTFLAGS) --extension"
-# only run upgrade test if RUNTESTFLAGS was not already doing that
-installcheck-upgrade: installcheck-upgrade-byfunc
-	if test -z `echo "$(RUNTESTFLAGS)" | grep -- --upgrade`; then \
-		$(MAKE) check-regress \
-			RUNTESTFLAGS="$(RUNTESTFLAGS) --extension \
-			--upgrade-path unpackaged--$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)"; \
-	fi
+installcheck-upgrade-base:
+	$(MAKE) installcheck-base \
+			RUNTESTFLAGS="$(RUNTESTFLAGS) \
+			--upgrade"
+installcheck-upgrade:
+	$(MAKE) installcheck-upgrade-from-unpackaged
+	$(MAKE) installcheck-upgrade-from-unpackaged-by-func
+	$(MAKE) installcheck-upgrade-from-packaged-by-func
+installcheck-upgrade-from-unpackaged:
+	$(MAKE) installcheck-upgrade-base \
+			--upgrade-path unpackaged--$(POSTGIS_FULL_VERSION)"
+installcheck-upgrade-from-unpackaged-by-func:
+			--upgrade-path unpackaged--$(POSTGIS_FULL_VERSION)!"
+installcheck-upgrade-from-packaged-by-func:
+			--upgrade-path $(POSTGIS_FULL_VERSION)--$(POSTGIS_FULL_VERSION)!"
-installcheck-upgrade-byfunc:
-			--upgrade-path unpackaged--$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)!" \
-			$(MAKE) check-regress; \
-	fi
 distclean: distclean-local
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 458822d8f..bfcec355d 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -226,20 +226,8 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   done
-  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
-  # Test current version to current version extension upgrade
-  UPGRADE_PATH="${CURRENTVERSION}--:auto!"
-  test_label="${EXT} extension-based upgrade ${UPGRADE_PATH}"
-  echo "Testing ${test_label}"
-  RUNTESTFLAGS="--extension -v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-  make -C ${REGDIR} check && {
-    echo "PASS: ${test_label}"
-    echo "FAIL: ${test_label}"
-    failed
   # Check unpackaged->unpackaged upgrades
+  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
   if test "${to_version}" = "${CURRENTVERSION}"; then
     for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`
     do #{
Summary of changes:
 GNUmakefile.in              | 42 ++++++++++++++++++++++++++++--------------
 utils/check_all_upgrades.sh | 14 +-------------
 2 files changed, 29 insertions(+), 27 deletions(-)
hooks/post-receive
