[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-168-gc7c8f05d8
Wed Oct 5 15:37:52 PDT 2022
the project "PostGIS".
       via  c7c8f05d8f397cc92b9f61c76eb19c13939fc1fa (commit)
      from  44d72533269d4729b4f2e2474ed4e503b5ddce4b (commit)
revisions in full, below.
commit c7c8f05d8f397cc92b9f61c76eb19c13939fc1fa
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 6 00:35:08 2022 +0200
    Fix PostgreSQL upgrade paths availability test (connect to template1)
    Or we'd be getting an error from psql, which would now be also
    intercepted
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index bfcec355d..c16436546 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -14,6 +14,9 @@ cd $(dirname $0)/..
 SRCDIR=$PWD # TODO: allow override ?
 cd - > /dev/null
+# This is useful to run database queries
+export PGDATABASE=template1
 if test "$1" = "-s"; then
   EXIT_ON_FIRST_FAILURE=1
@@ -129,7 +132,6 @@ compatible_upgrade()
 to_version_param="$1"
 to_version=$to_version_param
 if expr $to_version : ':auto' >/dev/null; then
-  export PGDATABASE=template1
   to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
 elif expr $to_version : '.*!$' >/dev/null; then
   to_version=$(echo "${to_version}" | sed 's/\!$//')
@@ -183,7 +185,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
         FROM pg_catalog.pg_extension_update_paths('${EXT}')
         WHERE source = '${from_version}'
         AND target = '${to_version}'
+    " ) || exit 1
     if test -z "${path}"; then
       echo "SKIP: ${test_label} (no upgrade path from ${from_version} to ${to_version} known by postgresql)"
       continue
@@ -211,7 +213,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
         WHERE source = 'unpackaged'
+    " ) || exit 1
       echo "SKIP: ${test_label} (no upgrade path from unpackaged to ${to_version} known by postgresql)"
       continue
Summary of changes:
 utils/check_all_upgrades.sh | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
