[postgis-tickets] [PostGIS] #5257: PG16 doesn't load against 3.4.0 (master)
PostGIS trac at osgeo.org
Sun Oct 9 20:31:47 PDT 2022
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  master
 Keywords:  PG16     |
 I was hoping to test strk's postgresql wildcard patch against PostGIS, but
 sadly they broke out code again.
 I confirmed debbie has the same issue
 ignore the version 3.3, it's testing master, just had that hard-coded in
 the paths
 ERROR:  could not load library
 "/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/3.3/regress/00
 -regress-install/lib/postgis-3.so":
 -regress-install/lib/postgis-3.so: undefined symbol: MemoryContextContains
 Issue seems to be here:
 shared_gserialized.o shared_gserialized.c
 shared_gserialized.c: In function ‘shared_gserialized_ref’:
 shared_gserialized.c:50:6: warning: implicit declaration of function
 ‘MemoryContextContains’; did you mean ‘MemoryContextStats’? [-Wimplicit-
 function-declaration]
    50 |  if (MemoryContextContains(PostgisCacheContext(fcinfo), ref))
       |      MemoryContextStats
 gcc-ar rs libpgcommon.a gserialized_gist.o lwgeom_transform.o
 lwgeom_cache.o lwgeom_pg.o shared_gserialized.o
 /usr/bin/ar: creating libpgcommon.a
 Also seeing these lovely warnings which I don't recall seeing in PG15
 gserialized_spgist_2d.c: In function ‘gserialized_spgist_picksplit_2d’:
 gserialized_spgist_2d.c:375:34: warning: passing argument 1 of
 ‘BoxPGetDatum’ from incompatible pointer type [-Wincompatible-pointer-
 types]
   375 |  out->prefixDatum = BoxPGetDatum(centroid);
       |                                  BOX2DF *
 In file included from ../libpgcommon/lwgeom_pg.h:22,
                  from gserialized_spgist_2d.c:81:
 /var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server/utils/geo_decls.h:239:25:
 note: expected ‘const BOX *’ but argument is of type ‘BOX2DF *’
   239 | BoxPGetDatum(const BOX *X)
 ‘gserialized_spgist_leaf_consistent_2d’:
 gserialized_spgist_2d.c:567:22: warning: passing argument 1 of
 ‘DatumGetPointer’ makes integer from pointer without a cast [-Wint-
 conversion]
   567 |  if (DatumGetPointer(key) == NULL)
       |                      BOX2DF *
 In file included from gserialized_spgist_2d.c:73:
 /var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server/postgres.h:660:23:
 note: expected ‘Datum’ {aka ‘long unsigned int’} but argument is of type
 ‘BOX2DF *’
   660 | DatumGetPointer(Datum X)
 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute
 -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local
 -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard
 -Wno-format-truncation -Wno-stringop-truncation -g -O2 -fPIC
 -fvisibility=hidden -I../liblwgeom -I../liblwgeom -std=gnu99 -g -O2 -fno-
 math-errno -fno-signed-zeros -Wall -I../libpgcommon -I../deps/flatgeobuf
 -I../deps/wagyu -I../deps/uthash/include
 -I/var/lib/jenkins/workspace/geos/rel-3.8w64/include
 -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c  -DNDEBUG
 -fPIC -DPIC -I. -I./
 -I/var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/server
 -I/var/lib/jenkins/workspace/pg/rel/pg16w64/include/postgresql/internal
 -D_GNU_SOURCE   -c -o gserialized_spgist_3d.o gserialized_spgist_3d.c
 gserialized_spgist_3d.c: In function ‘gserialized_spgist_picksplit_3d’:
 gserialized_spgist_3d.c:439:10: warning: declaration of ‘box’ shadows a
 previous local [-Wshadow=compatible-local]
   439 |   BOX3D *box = DatumGetBox3DP(in->datums[i]);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5257>
