[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-229-ge3b01ac7b
git at osgeo.org
git at osgeo.org
Thu Oct 20 07:01:00 PDT 2022
the project "PostGIS".
via e3b01ac7bce14ac5c93ab3f92dcc82dfbbcc0e34 (commit)
from 009004868bda8b495b4c8340239abe26b828250d (commit)
revisions in full, below.
commit e3b01ac7bce14ac5c93ab3f92dcc82dfbbcc0e34
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Oct 20 15:49:56 2022 +0200
Further cleanup run_test.pl error handling
diff --git a/regress/run_test.pl b/regress/run_test.pl
index ad83e8c6d..26eaa73f6 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -329,7 +329,7 @@ sub semver_lessthan
if ( $OPT_UPGRADE )
- print "Upgrading from postgis $libver\n";
+ print "Upgrading from postgis $libver\n";
foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
@@ -337,14 +337,14 @@ if ( $OPT_UPGRADE )
die unless load_sql_file($hook, 1);
- if ( $OPT_EXTENSIONS )
- upgrade_spatial_extensions();
- else
- upgrade_spatial();
+ if ( $OPT_EXTENSIONS )
+ die unless upgrade_spatial_extensions();
+ else
+ die unless upgrade_spatial();
foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
@@ -352,13 +352,13 @@ if ( $OPT_UPGRADE )
- # Update libver
- $libver = sql("select postgis_lib_version()");
+ # Update libver
+ $libver = sql("select postgis_lib_version()");
if ( $OPT_DUMPRESTORE )
- dump_restore();
+ die unless dump_restore();
@@ -1355,13 +1355,13 @@ sub create_spatial
- prepare_spatial_extensions();
+ exit($FAIL) unless prepare_spatial_extensions();
else
if ( ! $OPT_UPGRADE_FROM )
- prepare_spatial();
+ exit($FAIL) unless prepare_spatial();
return;
@@ -1374,7 +1374,7 @@ sub create_spatial
die "--upgrade-path without --extension is only supported with target :auto";
- prepare_spatial($1);
+ exit($FAIL) unless prepare_spatial($1);
@@ -1420,15 +1420,14 @@ sub prepare_spatial_extensions
my $rv = system($cmd);
if ( $rv ) {
fail "Error encountered creating target schema ${OPT_SCHEMA}", $REGRESS_LOG;
- die;
+ return 0;
my $sql = "CREATE EXTENSION postgis";
if ( $OPT_UPGRADE_FROM ) {
if ( $OPT_UPGRADE_FROM =~ /^unpackaged(.*)/ ) {
- return;
+ return prepare_spatial($1);
$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
@@ -1440,9 +1439,9 @@ sub prepare_spatial_extensions
my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
- if ( $rv ) {
- fail "Error encountered creating EXTENSION POSTGIS", $REGRESS_LOG;
- die;
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS", $REGRESS_LOG;
+ return 0;
if ( $OPT_WITH_TOPO )
@@ -1456,9 +1455,9 @@ sub prepare_spatial_extensions
$cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
- if ( $rv ) {
- fail "Error encountered creating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
- die;
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
+ return 0;
@@ -1473,9 +1472,9 @@ sub prepare_spatial_extensions
$rv = system($cmd);
- if ( $rv ) {
- fail "Error encountered creating EXTENSION POSTGIS_TIGER_GEOCODER", $REGRESS_LOG;
- die;
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_TIGER_GEOCODER", $REGRESS_LOG;
+ return 0;
@@ -1495,7 +1494,7 @@ sub prepare_spatial_extensions
$rv = system($cmd);
if ( $rv ) {
fail "Error encountered creating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
- die;
+ return 0;
@@ -1521,7 +1520,7 @@ sub prepare_spatial_extensions
$rv = system($cmd);
if ( $rv ) {
fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
- die;
+ return 0;
@@ -1539,29 +1538,29 @@ sub prepare_spatial
print "Loading PostGIS into '${DB}' \n";
# Load postgis.sql into the database
- load_sql_file("${scriptdir}/postgis.sql", 1);
- load_sql_file("${scriptdir}/postgis_comments.sql", 0);
- load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
+ return 0 unless load_sql_file("${scriptdir}/postgis.sql", 1);
+ return 0 unless load_sql_file("${scriptdir}/postgis_comments.sql", 0);
+ return 0 unless load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
print "Loading Topology into '${DB}'\n";
- load_sql_file("${scriptdir}/topology.sql", 1);
- load_sql_file("${scriptdir}/topology_comments.sql", 0);
+ return 0 unless load_sql_file("${scriptdir}/topology.sql", 1);
+ return 0 unless load_sql_file("${scriptdir}/topology_comments.sql", 0);
if ( $OPT_WITH_RASTER )
print "Loading Raster into '${DB}'\n";
- load_sql_file("${scriptdir}/rtpostgis.sql", 1);
- load_sql_file("${scriptdir}/raster_comments.sql", 0);
+ return 0 unless load_sql_file("${scriptdir}/rtpostgis.sql", 1);
+ return 0 unless load_sql_file("${scriptdir}/raster_comments.sql", 0);
if ( $OPT_WITH_SFCGAL )
print "Loading SFCGAL into '${DB}'\n";
- load_sql_file("${scriptdir}/sfcgal.sql", 1);
- load_sql_file("${scriptdir}/sfcgal_comments.sql", 0);
+ return 0 unless load_sql_file("${scriptdir}/sfcgal.sql", 1);
+ return 0 unless load_sql_file("${scriptdir}/sfcgal_comments.sql", 0);
return 1;
@@ -1605,27 +1604,27 @@ sub upgrade_spatial
my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
print "Upgrading core\n";
- die unless load_sql_file($script, 1);
+ return 0 unless load_sql_file($script, 1);
$script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
print "Upgrading topology\n";
$script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
print "Upgrading raster\n";
$script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
print "Upgrading sfcgal\n";
return 1;
@@ -1669,7 +1668,7 @@ sub upgrade_spatial_extensions
elsif ( $OPT_UPGRADE_FROM =~ /^unpackaged/ )
- $sql = package_extension_sql('postgis', ${nextver});
+ $sql = package_extension_sql('postgis', ${nextver});
else
@@ -1683,7 +1682,7 @@ sub upgrade_spatial_extensions
if ( $rv ) {
fail "Error encountered updating EXTENSION POSTGIS", $REGRESS_LOG;
- die;
+ return 0;
# Handle raster split if coming from pre-split extension
@@ -1703,7 +1702,7 @@ sub upgrade_spatial_extensions
if ( $rv ) {
fail "Error encountered creating EXTENSION POSTGIS_RASTER from unpackaged on upgrade", $REGRESS_LOG;
- die;
+ return 0;
if ( ! $OPT_WITH_RASTER )
@@ -1715,7 +1714,7 @@ sub upgrade_spatial_extensions
$rv = system($cmd);
if ( $rv ) {
fail "Error encountered dropping EXTENSION POSTGIS_RASTER on upgrade", $REGRESS_LOG;
- die;
+ return 0;
@@ -1743,7 +1742,7 @@ sub upgrade_spatial_extensions
if ( $rv ) {
fail "Error encountered updating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
- die;
+ return 0;
@@ -1764,7 +1763,7 @@ sub upgrade_spatial_extensions
if ( $rv ) {
fail "Error encountered updating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
- die;
+ return 0;
@@ -1792,7 +1791,7 @@ sub upgrade_spatial_extensions
$rv = system($cmd);
if ( $rv ) {
- die;
+ return 0;
@@ -1824,7 +1823,6 @@ sub drop_spatial_extensions
# ON_ERROR_STOP is used by psql to return non-0 on an error
my $psql_opts="--no-psqlrc --variable ON_ERROR_STOP=true";
- my $ok = 1;
my ($cmd, $rv);
@@ -1834,21 +1832,30 @@ sub drop_spatial_extensions
# http://trac.osgeo.org/postgis/ticket/2138
$cmd = "psql $psql_opts -c \"DROP EXTENSION postgis_topology; DROP SCHEMA topology;\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
- $ok = 0 if $rv;
+ if ( $rv ) {
+ fail "Error encountered dropping EXTENSION postgis_topology", $REGRESS_LOG;
+ return 0;
$cmd = "psql $psql_opts -c \"DROP EXTENSION postgis_sfcgal;\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
- $ok = 0 if $rv;
+ if ( $rv ) {
+ fail "Error encountered dropping EXTENSION postgis_sfcgal", $REGRESS_LOG;
+ return 0;
$cmd = "psql $psql_opts -c \"DROP EXTENSION IF EXISTS postgis_raster;\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
- $ok = 0 if $rv;
+ if ( $rv ) {
+ fail "Error encountered dropping EXTENSION postgis_raster", $REGRESS_LOG;
+ return 0;
if ( $OPT_WITH_TIGER )
@@ -1858,17 +1865,21 @@ sub drop_spatial_extensions
DROP SCHEMA IF EXISTS tiger_data;
$rv = system($cmd);
- $ok = 0 if $rv;
+ return 0 if $rv;
+ if ( $rv ) {
+ fail "Error encountered dropping EXTENSION postgis_tiger_geocoder", $REGRESS_LOG;
+ return 0;
$cmd = "psql $psql_opts -c \"DROP EXTENSION postgis\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
if ( $rv ) {
fail "Error encountered dropping EXTENSION POSTGIS", $REGRESS_LOG;
- die;
+ return 0;
- return $ok;
+ return 1;
# Drop spatial from an existing database
@@ -1905,51 +1916,51 @@ sub uninstall_spatial
# Dump and restore the database
sub dump_restore
- my $DBDUMP = $TMPDIR . '/' . $DB . ".dump";
- my $rv;
+ my $DBDUMP = $TMPDIR . '/' . $DB . ".dump";
+ my $rv;
print "Dumping and restoring database '${DB}'\n";
- $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
- if ( $rv ) {
- fail("Could not dump ${DB}", $REGRESS_LOG);
- die;
- $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
- if ( $rv ) {
- fail("Could not drop ${DB}", $REGRESS_LOG);
- die;
+ $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
+ if ( $rv ) {
+ fail("Could not dump ${DB}", $REGRESS_LOG);
+ return 0;
- $rv = create_db();
- if ( $rv ) {
- fail("Could not create ${DB}", $REGRESS_LOG);
- die;
+ $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
+ if ( $rv ) {
+ fail("Could not drop db ${DB}", $REGRESS_LOG);
+ return 0;
- $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
- if ( $rv ) {
- fail("Could not restore ${DB}", $REGRESS_LOG);
- die;
+ $rv = create_db();
+ if ( $rv ) {
+ fail("Could not create ${DB}", $REGRESS_LOG);
+ return 0;
- if ( $OPT_WITH_TOPO )
- # We need to re-add "topology" to the search_path as it is lost
- # on dump/reload, see https://trac.osgeo.org/postgis/ticket/3454
- my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
- my $cmd = "psql $psql_opts -c \"SELECT topology.AddToSearchPath('topology')\" $DB >> $REGRESS_LOG 2>&1";
- $rv = system($cmd);
+ $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
if ( $rv ) {
- fail("Error encountered adding topology to search path after restore", $REGRESS_LOG);
- die;
+ fail("Could not restore ${DB}", $REGRESS_LOG);
+ return 0;
+ if ( $OPT_WITH_TOPO )
+ # We need to re-add "topology" to the search_path as it is lost
+ # on dump/reload, see https://trac.osgeo.org/postgis/ticket/3454
+ my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+ my $cmd = "psql $psql_opts -c \"SELECT topology.AddToSearchPath('topology')\" $DB >> $REGRESS_LOG 2>&1";
+ $rv = system($cmd);
+ if ( $rv ) {
+ fail("Error encountered adding topology to search path after restore", $REGRESS_LOG);
+ return 0;
- unlink($DBDUMP);
+ unlink($DBDUMP);
- return 1;
+ return 1;
sub diff
Summary of changes:
regress/run_test.pl | 193 +++++++++++++++++++++++++++-------------------------
1 file changed, 102 insertions(+), 91 deletions(-)
hooks/post-receive
