[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-230-g1e96c9214
Thu Oct 20 21:23:11 PDT 2022
the project "PostGIS".
       via  1e96c9214ef814260d1d66247b3ffbde7a019b45 (commit)
      from  e3b01ac7bce14ac5c93ab3f92dcc82dfbbcc0e34 (commit)
revisions in full, below.
commit 1e96c9214ef814260d1d66247b3ffbde7a019b45
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Oct 21 00:18:34 2022 -0400
    FIX compile against PostgreSQL 16
    1) get_guc_variables() function now requires number variables reference.
    Change to not use this function at all and replace with find_option,
    which does much the same but with less code
    2) Abs function removed in PG16.  As noted in Discussion:
    https://www.postgresql.org/message-id/flat/4beb42b5-216b-bce8-d452-d924d5794c63%40enterprisedb.com
    We should be using C lib abs or fabs.  Replaced this left over use with
    fabs, which we are already using elsewhere
    Closes #5261 for PostGIS 3.4.0
diff --git a/NEWS b/NEWS
index c1a1d6114..b2d931c69 100644
--- a/NEWS
+++ b/NEWS
@@ -6,11 +6,11 @@ xxxx/xx/xx
 * New Features *
   - New install-extension-upgrades command in postgis script (Sandro Santilli)
-  - #5257, Remove MemoryContextContains use for PG16 (Regina Obe)
+  - #5257, #5261 Support changes for PG16 (Regina Obe)
 * Enhancements *
   - #5194, do not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)
-  - #5092, reduce number of upgrade paths installed on system (Sandro Santilli)
+  - #5092 reduce number of upgrade paths installed on system (Sandro Santilli)
 * Bug Fix *
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index e1724548b..dc751875b 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -496,16 +496,22 @@ postgis_guc_find_option(const char *name)
 	const char **key = &name;
 	struct config_generic **res;
+	int			numOpts;
 	 * By equating const char ** with struct config_generic *, we are assuming
 	 * the name field is first in config_generic.
+#if POSTGIS_PGSQL_VERSION >= 160
+	res = find_option(&key, false, true, ERROR);
+#else
 	res = (struct config_generic **) bsearch((void *) &key,
 		 (void *) get_guc_variables(),
 		 GetNumConfigOptions(),
 		 sizeof(struct config_generic *),
 		 postgis_guc_var_compare);
+#endif;
 	/* Found nothing? Good */
 	if ( ! res ) return 0;
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index a47c58d3e..0d6a0e938 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -2054,7 +2054,8 @@ Datum gserialized_gist_picksplit_2d(PG_FUNCTION_ARGS)
 			box = (BOX2DF *) DatumGetPointer(entryvec->vector[
 												commonEntries[i].index].key);
-			commonEntries[i].delta = Abs(box2df_penalty(leftBox, box) - box2df_penalty(rightBox, box));
+			/** PG!6 Abs was removed in favor of standard c lib **/
+			commonEntries[i].delta = fabs(box2df_penalty(leftBox, box) - box2df_penalty(rightBox, box));
Summary of changes:
 NEWS                          | 4 ++--
 libpgcommon/lwgeom_pg.c       | 6 ++++++
 postgis/gserialized_gist_2d.c | 3 ++-
 3 files changed, 10 insertions(+), 3 deletions(-)
hooks/post-receive
