[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Mon Oct 24 09:59:58 PDT 2022
 Reporter:  louisd                       |      Owner:  pramsey
     Type:  defect                       |     Status:  new
 Priority:  medium                       |  Milestone:  PostGIS 3.3.2
Component:  postgis                      |    Version:  3.3.x
 Keywords:  make install topology error  |
 Compiling postgis on alpine/musl with postgresql 15 (also tested with
 14.5) works with version 3.1.7 but other newer versions (tested with 3.2.1
 and 3.3.1) fail at the make install step. Workaround found, explained
 below.
  (./configure.sh and make were executed on both versions before the "make
 install" step shown here)
 bash-5.1# cd /install/postgis-3.1.7/topology
 bash-5.1# make install
 /bin/sh /usr/local/pgsql/lib/pgxs/src/makefiles/../../config/install-sh -c
 -d '/usr/local/pgsql/lib'
 -d '/usr/local/pgsql/share/contrib/postgis-3.1'
 /usr/bin/install -c -m 755  postgis_topology-3.so
 '/usr/local/pgsql/lib/postgis_topology-3.so'
 /usr/bin/install -c -m 644  topology.sql topology_upgrade.sql
 uninstall_topology.sql '/usr/local/pgsql/share/contrib/postgis-3.1/'
 bash-5.1# cd /install/postgis-3.3.1/topology
 /bin/sh ../config/install-sh -c -d '/usr/local/pgsql/lib'
 /bin/sh: can't open '../config/install-sh': No such file or directory
 make: ***
 [/usr/local/pgsql/lib/pgxs/src/makefiles/../../src/Makefile.shlib:471:
 installdirs-lib] Error 2
 The difference between the two seems to be the ../config/install-sh
 (relative path) instead of the full path in the working version
 :/usr/local/pgsql/lib/pgxs/src/makefiles/../../config/install-sh)
 Fix applied for now (for me) is:
 ln -s /usr/local/pgsql/lib/pgxs/config /install/postgis-3.3.1
 Then, execution completes correctly:
 bash-5.1# ln -s /usr/local/pgsql/lib/pgxs/config /install/postgis-3.3.1
 '/usr/local/pgsql/share/contrib/postgis-3.3'
 mkdir -p /usr/local/pgsql/bin
 /bin/sh ../libtool --mode=install /usr/bin/install -c loader/pgtopo_import
 "/usr/local/pgsql/bin/pgtopo_import"
 libtool: install: /usr/bin/install -c loader/pgtopo_import
 /bin/sh ../libtool --mode=install /usr/bin/install -c loader/pgtopo_export
 "/usr/local/pgsql/bin/pgtopo_export"
 libtool: install: /usr/bin/install -c loader/pgtopo_export
 uninstall_topology.sql '/usr/local/pgsql/share/contrib/postgis-3.3/'
 Another workaround is to ./configure.sh --without-topology
 it works, but this is not an option for me since topology is needed in our
 database.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264>
