[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Mon Oct 24 10:05:47 PDT 2022
  Reporter:  louisd   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.2
 Component:  postgis  |    Version:  3.3.x
Resolution:           |   Keywords:  make install topology error
Description changed by louisd:
Old description:
> Compiling postgis on alpine/musl with postgresql 15 (also tested with
> 14.5) works with version 3.1.7 but other newer versions (tested with
> 3.2.1 and 3.3.1) fail at the make install step. Workaround found,
> explained below.
>  (./configure.sh and make were executed on both versions before the "make
> install" step shown here)
> bash-5.1# cd /install/postgis-3.1.7/topology
> bash-5.1# make install
> /bin/sh /usr/local/pgsql/lib/pgxs/src/makefiles/../../config/install-sh
> -c -d '/usr/local/pgsql/lib'
> -c -d '/usr/local/pgsql/share/contrib/postgis-3.1'
> /usr/bin/install -c -m 755  postgis_topology-3.so
> '/usr/local/pgsql/lib/postgis_topology-3.so'
> /usr/bin/install -c -m 644  topology.sql topology_upgrade.sql
> uninstall_topology.sql '/usr/local/pgsql/share/contrib/postgis-3.1/'
> bash-5.1# cd /install/postgis-3.3.1/topology
> /bin/sh ../config/install-sh -c -d '/usr/local/pgsql/lib'
> /bin/sh: can't open '../config/install-sh': No such file or directory
> make: ***
> [/usr/local/pgsql/lib/pgxs/src/makefiles/../../src/Makefile.shlib:471:
> installdirs-lib] Error 2
> The difference between the two seems to be the ../config/install-sh
> (relative path) instead of the full path in the working version
> :/usr/local/pgsql/lib/pgxs/src/makefiles/../../config/install-sh)
> Fix applied for now (for me) is:
> ln -s /usr/local/pgsql/lib/pgxs/config /install/postgis-3.3.1
> Then, execution completes correctly:
> bash-5.1# ln -s /usr/local/pgsql/lib/pgxs/config /install/postgis-3.3.1
> '/usr/local/pgsql/share/contrib/postgis-3.3'
> mkdir -p /usr/local/pgsql/bin
> /bin/sh ../libtool --mode=install /usr/bin/install -c
> loader/pgtopo_import "/usr/local/pgsql/bin/pgtopo_import"
> libtool: install: /usr/bin/install -c loader/pgtopo_import
> loader/pgtopo_export "/usr/local/pgsql/bin/pgtopo_export"
> libtool: install: /usr/bin/install -c loader/pgtopo_export
> uninstall_topology.sql '/usr/local/pgsql/share/contrib/postgis-3.3/'
> Another workaround is to ./configure.sh --without-topology
> it works, but this is not an option for me since topology is needed in
> our database.
New description:
 14.5) works with version 3.1.7 but other newer versions (tested with 3.2.1
 and 3.3.1) fail at the make install step. Workaround found, explained
 below.
 /bin/sh /usr/local/pgsql/lib/pgxs/src/makefiles/../../config/install-sh -c
 make: ***
 /bin/sh ../libtool --mode=install /usr/bin/install -c loader/pgtopo_import
 /bin/sh ../libtool --mode=install /usr/bin/install -c loader/pgtopo_export
 it works, but this is not an option for me since topology is needed in our
 database.
 Also tested with the latest git clone done today.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:1>
