[postgis-tickets] [PostGIS] #5269: Berrie failing on installing shp2pgsql pgsql2shp
PostGIS trac at osgeo.org
Wed Oct 26 18:53:46 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 05:55:07 ---- Making install in loader
 05:55:07 make[1]: Entering directory
 '/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie/8a73d5ee4ea69f318deda4ad3f72ee4cb5f20371/loader'
 05:55:07 /bin/bash ../libtool --mode=install /usr/bin/install -c pgsql2shp
 "/usr/local/bin/pgsql2shp"
 05:55:07 libtool: install: /usr/bin/install -c pgsql2shp
 05:55:07 /usr/bin/install: cannot create regular file
 '/usr/local/bin/pgsql2shp': Permission denied
 05:55:07 make[1]: *** [Makefile:148: install] Error 1
 05:55:07 make[1]: Leaving directory
 05:55:07 make: *** [GNUmakefile:25: install] Error 1
 05:55:08 Build step 'Execute shell' marked build as failure
 05:55:13 Finished: FAILURE
 I assume this is a result of this:
 [8a73d5ee4e/git]
 So the cis need to be changed to now use the prefix
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5269>
