[postgis-tickets] [PostGIS] #5269: Berrie failing on installing shp2pgsql pgsql2shp
PostGIS trac at osgeo.org
Wed Oct 26 19:07:05 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"0415ccb6da8a8b313302c874cff2359e596fd982/git"
 0415ccb6/git]:
 {{{#!CommitTicketReference repository="git"
 revision="0415ccb6da8a8b313302c874cff2359e596fd982"
 More cleanup of berrie64 script
 Change berries to use --prefix so they don't install shp2pgsql/pgsql2shp
 in system location
 Closes #5269 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5269#comment:1>
