[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Thu Oct 27 04:20:11 PDT 2022
  Reporter:  louisd    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.3.2
 Component:  topology  |    Version:  3.3.x
Resolution:            |   Keywords:  make install topology error
Comment (by strk):
 Does adding INSTALL=@INSTALL@ in the topology/Makefile.in and re-running
 configure work for you ?
 I'm not sure how the INSTALL variable ends up being set differently under
 postgis/ and topology/ but I guess it must be due to some variable being
 defined or not at the time of include. Maybe `srcdir := @srcdir@` which I
 see in postgis/Makefile.in but not in topology/Makefile.in
 I cannot reproduce locally so can't easily tell if those actions fix the
 problem for you
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:3>
