[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Thu Oct 27 04:23:57 PDT 2022
  Reporter:  louisd    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.3.2
 Component:  topology  |    Version:  3.3.x
Resolution:            |   Keywords:  make install topology error
Comment (by strk):
 NOTE: I just found that INSTALL=@INSTALL@ is already present in the master
 branch for topology/Makefile.in -- what's the value you get in the
 generated topology/Makefile for it ? The same variable is NOT set in the
 3.1 and 3.2 branches (but you do see a difference between those two ?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:4>
