[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Fri Oct 28 07:36:19 PDT 2022
  Reporter:  louisd    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.3.2
 Component:  topology  |    Version:  3.3.x
Resolution:            |   Keywords:  make install topology error
Comment (by louisd):
 Hi, thanks for responding!
 after configure for both versions, here is what I see:
 bash-5.1# more postgis-3.1.7/topology/Makefile | grep INSTALL
 # NO_TEMP_INSTALL is a workaround for a 9.5dev bug. See:
 NO_TEMP_INSTALL=yes
 bash-5.1# more postgis-3.3.1/topology/Makefile | grep INSTALL
 NO_TEMP_INSTALL=yes
 INSTALL = /usr/bin/install -c
         $(LIBTOOL) --mode=install $(INSTALL) $^
 "$(DESTDIR)$(bindir)/pgtopo_import"
 "$(DESTDIR)$(bindir)/pgtopo_export"
 Looking at Makefile.in, I have:
 bash-5.1# more postgis-3.1.7/topology/Makefile.in | grep INSTALL
 NO_TEMP_INSTALL=yes
 bash-5.1# more postgis-3.3.1/topology/Makefile.in | grep INSTALL
 NO_TEMP_INSTALL=yes
 INSTALL = @INSTALL@
 As for srcdir, here it is: (nothing)
 bash-5.1# more postgis-3.1.7/topology/Makefile | grep srcdir
 bash-5.1# more postgis-3.3.1/topology/Makefile | grep srcdir
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:5>
