[postgis-tickets] [PostGIS] #5081: toTopoGeom: ERROR: ptarray_scroll_in_place: input POINTARRAY does not contain the given point
trac at osgeo.org
Fri Oct 28 04:35:26 PDT 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.0
Component: topology | Version: 3.2.x
Resolution: | Keywords:
Comment (by strk):
In my new case the problem occurs when the input closed line becomes a
multiline. In that case the code that re-computes the start/endpoint after
noding/snapping does not try to re-compute them (maybe it should)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5081#comment:3>
