[postgis-tickets] [PostGIS] #5081: ERROR: ptarray_scroll_in_place: input POINTARRAY does not contain the given point (was: toTopoGeom: ERROR: ptarray_scroll_in_place: input POINTARRAY does not contain the given point)
PostGIS trac at osgeo.org
Fri Oct 28 05:56:03 PDT 2022
given point
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:
Changes (by strk):
 * summary:
     given point
Comment:
 TopoGeo_addLinestring() is enough to trigger the problem, passing a closed
 linestring with more than 1 self-intersection should be enough to trigger
 the problem (only 2 resulting closed lines would contain the original
 start point)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5081#comment:4>
