[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-301-gce9f8b5e3
Mon Oct 31 18:41:15 PDT 2022
the project "PostGIS".
       via  ce9f8b5e3039ebf6bef7fb7c23059ba211ea29cb (commit)
      from  f94d56cf7c0d48bd2a2db597c7efd0c8bf4fd904 (commit)
revisions in full, below.
commit ce9f8b5e3039ebf6bef7fb7c23059ba211ea29cb
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Oct 31 21:41:06 2022 -0400
    Add a what's new section for 3.4
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index 75cd9f95a..19131b8b0 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -479,7 +479,107 @@
 	   <sect1 id="NewFunctions">
 			<title>New, Enhanced or changed PostGIS Functions</title>
-						<sect2 id="NewFunctions_3_3">
+				<sect2 id="NewFunctions_3_4">
+					<title>PostGIS Functions new or enhanced in 3.4</title>
+					<para>The functions given below are PostGIS functions that were added or enhanced.</para>
+					<xsl:if test="//para[contains(text(),'Availability: 3.4')]">
+					<para>Functions new in PostGIS 3.4</para>
+					<itemizedlist>
+					<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+						<xsl:for-each select='//refentry'>
+							<xsl:sort select="refnamediv/refname"/>
+							<xsl:variable name='comment'>
+								<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+							</xsl:variable>
+							<xsl:variable name="refid">
+								<xsl:value-of select="@id" />
+							</xsl:variable>
+							<xsl:variable name="refname">
+								<xsl:value-of select="refnamediv/refname" />
+							</xsl:variable>
+					<!-- For each section if there is note about availability in this version -->
+								<xsl:for-each select="refsection">
+									<xsl:for-each select="para | */para">
+										<xsl:choose>
+											<xsl:when test="contains(.,'Availability: 3.4')">
+												<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+											</xsl:when>
+										</xsl:choose>
+									</xsl:for-each>
+								</xsl:for-each>
+						</xsl:for-each>
+					</itemizedlist>
+					</xsl:if>
+					<xsl:if test="//para[contains(text(),'Enhanced: 3.4')]">
+					<para>Functions enhanced in PostGIS 3.4</para>
+					<itemizedlist>
+							</xsl:variable>
+							</xsl:variable>
+							</xsl:variable>
+										<xsl:choose>
+											<xsl:when test="contains(.,'Enhanced: 3.4')">
+											</xsl:when>
+										</xsl:choose>
+									</xsl:for-each>
+								</xsl:for-each>
+						</xsl:for-each>
+					</itemizedlist>
+				</xsl:if>
+				<para>Functions changed in PostGIS 3.4</para>
+					<xsl:if test="//para[contains(text(),'Changed: 3.4')]">
+					<itemizedlist>
+							</xsl:variable>
+							</xsl:variable>
+							</xsl:variable>
+										<xsl:choose>
+											<xsl:when test="contains(.,'Changed: 3.4')">
+											</xsl:when>
+										</xsl:choose>
+									</xsl:for-each>
+								</xsl:for-each>
+						</xsl:for-each>
+					</itemizedlist>
+					</xsl:if>
+				</sect2>
+				<sect2 id="NewFunctions_3_3">
 				<title>PostGIS Functions new or enhanced in 3.3</title>
         <xsl:if test="//para[contains(text(),'Availability: 3.3')]">
Summary of changes:
 doc/xsl/postgis_aggs_mm.xml.xsl | 102 +++++++++++++++++++++++++++++++++++++++-
 1 file changed, 101 insertions(+), 1 deletion(-)
hooks/post-receive
