[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-302-g065801907
Mon Oct 31 20:05:03 PDT 2022
the project "PostGIS".
       via  065801907c0f44d0700cf9ba95a0fed176e8fdeb (commit)
      from  ce9f8b5e3039ebf6bef7fb7c23059ba211ea29cb (commit)
revisions in full, below.
commit 065801907c0f44d0700cf9ba95a0fed176e8fdeb
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Oct 31 23:04:07 2022 -0400
    1. Add availability information for ST_TransformPipeline and
    ST_InversePipeline
    2. Break ST_TransformPipeline and ST_InversePipeline into two separate
    entries
diff --git a/doc/reference_srs.xml b/doc/reference_srs.xml
index f03776c7d..103bd503d 100644
--- a/doc/reference_srs.xml
+++ b/doc/reference_srs.xml
@@ -9,6 +9,84 @@
     <title>Spatial Reference System Functions</title>
+  <refentry id="ST_InverseTransformPipeline">
+    <refnamediv>
+    <refname>ST_InverseTransformPipeline</refname>
+    <refpurpose>Return a new geometry with coordinates transformed to
+      a different spatial reference system using the reverse of a defined coordinate
+      transformation pipeline.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+      <funcsynopsis>
+        <funcprototype>
+          <funcdef>geometry <function>ST_InverseTransformPipeline</function></funcdef>
+          <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+          <paramdef><type>text </type> <parameter>pipeline</parameter></paramdef>
+          <paramdef choice="opt"><type>integer </type> <parameter>to_srid</parameter></paramdef>
+        </funcprototype>
+      </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+    <title>Description</title>
+      <para>
+      Return a new geometry with coordinates transformed to a different spatial reference system
+      using the reverse of a defined coordinate transformation pipeline.
+      </para>
+      <para> Refer to <xref linkend="ST_TransformPipeline" /> for details on writing a transformation pipeline.</para>
+    <para>Availability: 3.4.0</para>
+    <para>
+    The SRID of the input geometry is ignored, and the SRID of the output geometry will be set to
+    zero unless a value is provided via the optional <varname>to_srid</varname> parameter. When
+    using <xref linkend="ST_TransformPipeline" /> the pipeline is executed in a forward direction. Using
+    `ST_InverseTransformPipeline()` the pipeline is executed in the inverse direction.</para>
+    <para>Transforms using pipelines are a specialised version of <xref linkend="ST_Transform" />.
+    In most cases `ST_Transform` will choose the correct operations to convert between coordinate
+    systems, and should be preferred.</para>
+    </refsection>
+    <refsection>
+    <title>Examples</title>
+    <para>Change WGS 84 long lat to UTM 31N using the EPSG:16031 conversion</para>
+    <programlisting>
+-- Inverse direction
+SELECT ST_AsText(ST_InverseTransformPipeline('POINT(426857.9877165967 5427937.523342293)'::geometry,
+  'urn:ogc:def:coordinateOperation:EPSG::16031')) AS wgs_geom;
+          wgs_geom
+ POINT(2 48.99999999999999)
+(1 row)
+    </programlisting>
+    <para>GDA2020 example.</para>
+    <programlisting>
+-- using ST_Transform with automatic selection of a conversion pipeline.
+SELECT ST_AsText(ST_Transform('SRID=4939;POINT(143.0 -37.0)'::geometry, 7844)) AS gda2020_auto;
+                 gda2020_auto
+ POINT(143.00000635638918 -36.999986706128176)
+(1 row)
+    </programlisting>
+    </refsection>
+    <!-- Optionally add a "See Also" section -->
+    <refsection>
+    <title>See Also</title>
+    <para><xref linkend="ST_Transform" />, <xref linkend="ST_TransformPipeline" /></para>
+    </refsection>
+  </refentry>
   <refentry id="ST_SetSRID">
     <refnamediv>
     <refname>ST_SetSRID</refname>
@@ -287,21 +365,14 @@ CREATE INDEX idx_geom_26986_parcels
     </refnamediv>
     <refsynopsisdiv>
-      <funcsynopsis>
-        <funcprototype>
-          <funcdef>geometry <function>ST_TransformPipeline</function></funcdef>
-          <paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
-          <paramdef><type>text </type> <parameter>pipeline</parameter></paramdef>
-          <paramdef choice="opt"><type>integer </type> <parameter>to_srid</parameter></paramdef>
-        </funcprototype>
-        <funcprototype>
-          <funcdef>geometry <function>ST_InverseTransformPipeline</function></funcdef>
-          <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
-        </funcprototype>
-      </funcsynopsis>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>geometry <function>ST_TransformPipeline</function></funcdef>
+                <paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
     </refsynopsisdiv>
     <refsection>
@@ -338,12 +409,13 @@ CREATE INDEX idx_geom_26986_parcels
           </listitem>
         </itemizedlist>
     </para>
     <para>
     using `ST_TransformPipeline()` the pipeline is executed in a forward direction. Using
-    `ST_InverseTransformPipeline()` the pipeline is executed in the inverse direction.</para>
+   <xref linkend="ST_InverseTransformPipeline" /> the pipeline is executed in the inverse direction.</para>
@@ -413,7 +485,7 @@ SELECT ST_AsText(ST_TransformPipeline('SRID=4939;POINT(143.0 -37.0)'::geometry,
     <refsection>
-    <para><xref linkend="ST_Transform" /></para>
+    <para><xref linkend="ST_Transform" />, <xref linkend="ST_InverseTransformPipeline" /></para>
     </refsection>
   </refentry>
Summary of changes:
 doc/reference_srs.xml | 106 ++++++++++++++++++++++++++++++++++++++++++--------
 1 file changed, 89 insertions(+), 17 deletions(-)
hooks/post-receive
