[postgis-tickets] [PostGIS] #5230: Build out trisquel3 ci docker container
PostGIS trac at osgeo.org
Fri Sep 2 21:05:34 PDT 2022
 Reporter:  robe         |      Owner:  robe
     Type:  enhancement  |     Status:  new
 Priority:  blocker      |  Milestone:  PostGIS 3.4.0
Component:  buildbots    |    Version:  master
 Keywords:               |
 trisquel2 is based has proj < 6 (I think it's 5.2) so too old to test 3.4.
 Rather than mess with it I created a trisquel3 which is based in
 kpengboy/trisquel:10.0 (and postgresql packages for focal).
 I've added to here https://git.osgeo.org/gitea/postgis/postgis-
 docker/src/branch/master/build-test/Dockerfile.trisquel3  and running the
 build now.
 Once it's done building, I'll put it to work in master.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5230>
