[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-25-g3e38e0b83
Fri Sep 2 17:15:03 PDT 2022
the project "PostGIS".
       via  3e38e0b83b98925122bb22dff958a7a603ee4a42 (commit)
      from  2428842e84fc6b6ce8a15fcfe9a17d888cd0eaa5 (commit)
revisions in full, below.
commit 3e38e0b83b98925122bb22dff958a7a603ee4a42
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 2 19:56:48 2022 -0400
    Remove support for PostgreSQL < 12
    Remove support for Proj < 6.1
    Closes #5229 for PostGIS 3.4.0
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 455204ae8..604b4a4c0 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -21,7 +21,7 @@ jobs:
         - { tag: pg15-clang-geos311-gdal35-proj90, mode: usan_clang }
         # - { tag: pg13-geos39-gdal31-proj71, mode: garden }
         - { tag: pg14-geos39-gdal33-proj71, mode: tests }
-        - { tag: pg14-clang-geosmain-gdal34-proj71, mode: usan_clang }
+        - { tag: pg14-clang-geos310-gdal34-proj71, mode: usan_clang }
         #- { tag: pg13-geos39-gdal31-proj71, mode: tests }
         #- { tag: pg13-geos39-gdal31-proj71, mode: coverage }
         - { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
@@ -30,7 +30,7 @@ jobs:
         # - { tag: latest, mode: tests }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
         - { tag: pg12-geos37-gdal30-proj611, mode: tests }
-        - { tag: pg11-geos37-gdal24-proj52, mode: tests }
+        # - { tag: pg11-geos37-gdal24-proj52, mode: tests }
         # - { tag: pg10-geos36-gdal23-proj49, mode: tests }
         # - { tag: pg96-geos36-gdal22-proj49, mode: tests }
diff --git a/NEWS b/NEWS
index 6e2afc448..121188d7a 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,9 @@
 PostGIS 3.4.0dev
 xxxx/xx/xx
+* Breaking Changes *
+- #5229, Drop support for Proj < 6.1 and PG 11 (Regina Obe)
 PostGIS 3.3.0
 2022/08/26
diff --git a/configure.ac b/configure.ac
index 98dcc3fd2..764e3c51a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -505,9 +505,9 @@ if test "x$LIBLWGEOM_ONLY" = "xno"; then
   PGSQL_SHAREDIR=`"$PG_CONFIG" --sharedir`
   AC_MSG_RESULT([checking PostgreSQL version... $PGSQL_FULL_VERSION])
-  dnl Ensure that we are using PostgreSQL >= 11
-  if test $POSTGIS_PGSQL_VERSION -lt 110; then
-    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 11])
+  dnl Ensure that we are using PostgreSQL >= 12
+  if test $POSTGIS_PGSQL_VERSION -lt 120; then
+    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 12])
   fi
   HAVE_SPGIST=yes
@@ -925,9 +925,9 @@ AC_DEFINE_UNQUOTED([POSTGIS_PROJ_VERSION], [$POSTGIS_PROJ_VERSION], [PROJ librar
 AC_SUBST([POSTGIS_PROJ_VERSION])
 CPPFLAGS="$CPPFLAGS_SAVE"
-dnl Ensure that we are using PROJ >= 4.9.0 (requires pj_set_searchpath)
-if test ! "$POSTGIS_PROJ_VERSION" -ge 49; then
-	AC_MSG_ERROR([PostGIS requires PROJ >= 4.9.0])
+dnl Ensure that we are using PROJ >= 6.1.0 (requires pj_set_searchpath)
+if test ! "$POSTGIS_PROJ_VERSION" -ge 61; then
+	AC_MSG_ERROR([PostGIS requires PROJ >= 6.1.0])
 fi
 AC_SUBST([PROJ_CPPFLAGS])
diff --git a/doc/postgis.xml b/doc/postgis.xml
index b47f7c893..70a4c2784 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -4,7 +4,7 @@
 <!-- This value is automatically generated by the Makefile -->
 <!ENTITY last_release_version "@@LAST_RELEASE_VERSION@@">
-<!ENTITY last_minor_version "3.2">
+<!ENTITY last_minor_version "3.3">
 <!-- ONCE Tagged, this need to change to http://download.osgeo.org/postgis/source/postgis-@@LAST_RELEASE_VERSION@@.tar.gz -->
 <!-- In dev should be, this need to change to http://postgis.net/stuff/postgis-@@LAST_RELEASE_VERSION@@.tar.gz -->
@@ -13,7 +13,7 @@
 <!-- Change these values to update the version numbers referenced within the documentation -->
 <!ENTITY last_proj_release_version "9.0.1">
 <!ENTITY last_geos_release_version "3.11.0">
-<!ENTITY min_postgres_version "11">
+<!ENTITY min_postgres_version "12">
 <!ENTITY max_postgres_version "15">
 <!ENTITY introduction SYSTEM "introduction.xml">
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 7ffffa8a7..e696d56de 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -35,21 +35,6 @@
 #include "../postgis_config.h"
-#if POSTGIS_PROJ_VERSION < 61
-/* For Proj 6.0 use of old API */
-#define ACCEPT_USE_OF_DEPRECATED_PROJ_API_H
-#include "proj_api.h"
-typedef struct PJ
-    projPJ pj_from;
-    projPJ pj_to;
-} PJ;
-typedef PJ LWPROJ;
-#else
 #include "proj.h"
 /* For PROJ6 we cache several extra values to avoid calls to proj_get_source_crs
@@ -64,15 +49,11 @@ typedef struct LWPROJ
     double source_semi_major_metre;
     double source_semi_minor_metre;
 } LWPROJ;
-#endif
-#if POSTGIS_PROJ_VERSION < 49
-/* Use the old (pre-2.2) geodesic functions */
-#undef PROJ_GEODESIC
-#else
 /* Enable new geodesic functions API */
 #define PROJ_GEODESIC
-#endif
 * @file liblwgeom.h
@@ -2460,16 +2441,6 @@ int lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outst
 int lwgeom_transform(LWGEOM *geom, LWPROJ* pj);
 int ptarray_transform(POINTARRAY *pa, LWPROJ* pj);
- * Get a projection from a string representation
- * Eg: "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
-projPJ projpj_from_string(const char* txt);
-#else // POSTGIS_PROJ_VERSION >= 61
  * Allocate a new LWPROJ containing the reference to the PROJ's PJ
  * If extra_geography_data is true, it will generate the following values for
@@ -2477,9 +2448,6 @@ projPJ projpj_from_string(const char* txt);
 LWPROJ *lwproj_from_str(const char* str_in, const char* str_out);
-#endif
  * GEOS-dependent extra functions on LWGEOM
diff --git a/liblwgeom/lwgeom_transform.c b/liblwgeom/lwgeom_transform.c
index e9bc859c9..d761293bf 100644
--- a/liblwgeom/lwgeom_transform.c
+++ b/liblwgeom/lwgeom_transform.c
@@ -46,112 +46,6 @@ to_dec(POINT4D *pt)
-static int
-point4d_transform(POINT4D *pt, LWPROJ *pj)
-	POINT3D orig_pt = {pt->x, pt->y, pt->z}; /* Copy for error report*/
-	if (pj_is_latlong(pj->pj_from)) to_rad(pt) ;
-	LWDEBUGF(4, "transforming POINT(%f %f) from '%s' to '%s'",
-		 orig_pt.x, orig_pt.y, pj_get_def(pj->pj_from,0), pj_get_def(pj->pj_to,0));
-	if (pj_transform(pj->pj_from, pj->pj_to, 1, 0, &(pt->x), &(pt->y), &(pt->z)) != 0)
-		int pj_errno_val = *pj_get_errno_ref();
-		if (pj_errno_val == -38)
-			lwnotice("PostGIS was unable to transform the point because either no grid"
-				 " shift files were found, or the point does not lie within the "
-				 "range for which the grid shift is defined. Refer to the "
-				 "ST_Transform() section of the PostGIS manual for details on how "
-				 "to configure PostGIS to alter this behaviour.");
-			lwerror("transform: couldn't project point (%g %g %g): %s (%d)",
-				orig_pt.x, orig_pt.y, orig_pt.z,
-				pj_strerrno(pj_errno_val), pj_errno_val);
-		else
-			lwerror("transform: %s (%d)",
-		return LW_FAILURE;
-	if (pj_is_latlong(pj->pj_to)) to_dec(pt);
-	return LW_SUCCESS;
- * Transform given POINTARRAY
- * from inpj projection to outpj projection
-int
-ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
-	uint32_t i;
-	POINT4D p;
-	for ( i = 0; i < pa->npoints; i++ )
-		getPoint4d_p(pa, i, &p);
-		if ( ! point4d_transform(&p, pj) ) return LW_FAILURE;
-		ptarray_set_point4d(pa, i, &p);
-int
-lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outstr)
-	char *pj_errstr;
-	int rv;
-	LWPROJ pj;
-	pj.pj_from = projpj_from_string(instr);
-	if (!pj.pj_from)
-		pj_errstr = pj_strerrno(*pj_get_errno_ref());
-		if (!pj_errstr) pj_errstr = "";
-		lwerror("could not parse proj string '%s'", instr);
-	pj.pj_to = projpj_from_string(outstr);
-	if (!pj.pj_to)
-		pj_free(pj.pj_from);
-		lwerror("could not parse proj string '%s'", outstr);
-	rv = lwgeom_transform(geom, &pj);
-	pj_free(pj.pj_to);
-	return rv;
-projPJ
-projpj_from_string(const char *str1)
-	if (!str1 || str1[0] == '\0')
-		return NULL;
-	return pj_init_plus(str1);
-#else /* POSTGIS_PROJ_VERION >= 61 */
 LWPROJ *
@@ -346,8 +240,6 @@ ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
 	return LW_SUCCESS;
-#endif
  * Transform given LWGEOM geometry
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index ce8c05543..e1724548b 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -55,9 +55,7 @@ postgisConstants *POSTGIS_CONSTANTS = NULL;
 static Oid TypenameNspGetTypid(const char *typname, Oid nsp_oid)
 	return GetSysCacheOid2(TYPENAMENSP,
-#if POSTGIS_PGSQL_VERSION >= 120
 	                       Anum_pg_type_oid,
-#endif
 	                       PointerGetDatum(typname),
 	                       ObjectIdGetDatum(nsp_oid));
@@ -75,19 +73,11 @@ postgis_get_extension_schema(Oid ext_oid)
     HeapTuple   tuple;
     ScanKeyData entry[1];
-#if POSTGIS_PGSQL_VERSION < 120
-    Relation rel = heap_open(ExtensionRelationId, AccessShareLock);
-    ScanKeyInit(&entry[0],
-	    ObjectIdAttributeNumber,
-        BTEqualStrategyNumber, F_OIDEQ,
-        ObjectIdGetDatum(ext_oid));
-#else
     Relation rel = table_open(ExtensionRelationId, AccessShareLock);
     	Anum_pg_extension_oid,
-#endif /* POSTGIS_PGSQL_VERSION */
     scandesc = systable_beginscan(rel, ExtensionOidIndexId, true,
                                   NULL, 1, entry);
@@ -102,11 +92,7 @@ postgis_get_extension_schema(Oid ext_oid)
     systable_endscan(scandesc);
-    heap_close(rel, AccessShareLock);
-#else
     table_close(rel, AccessShareLock);
-#endif
     return result;
@@ -533,31 +519,6 @@ postgis_guc_find_option(const char *name)
-Datum
-CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2, Datum arg3)
-	FunctionCallInfoData fcinfo;
-	Datum		result;
-	InitFunctionCallInfoData(fcinfo, flinfo, 3, collation, NULL, NULL);
-	fcinfo.arg[0] = arg1;
-	fcinfo.arg[1] = arg2;
-	fcinfo.arg[2] = arg3;
-	fcinfo.argnull[0] = false;
-	fcinfo.argnull[1] = false;
-	fcinfo.argnull[2] = false;
-	result = (*func) (&fcinfo);
-	/* Check for null result, since caller is clearly not expecting one */
-	if (fcinfo.isnull)
-		elog(ERROR, "function %p returned NULL", (void *) func);
-	return result;
-#else
 /* PgSQL 12+ still lacks 3-argument version of these functions */
 Datum
@@ -582,4 +543,3 @@ CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum
     return result;
-#endif
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index d14937028..51ffe77cb 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -253,10 +253,6 @@ void lwpgerror(const char *fmt, ...);
 void lwpgnotice(const char *fmt, ...);
 void lwpgwarning(const char *fmt, ...);
-#if POSTGIS_PGSQL_VERSION < 100
-Datum CallerFInfoFunctionCall1(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1);
-Datum CallerFInfoFunctionCall2(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2);
-#endif
 Datum CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2, Datum arg3);
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index 3972b914c..95394bddb 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -67,25 +67,12 @@ static void
 PROJSRSDestroyPJ(void *projection)
 	LWPROJ *pj = (LWPROJ *)projection;
-/* Ape the Proj 6+ API for versions < 6.1 */
-	if (pj->pj_from)
-		pj_free(pj->pj_from);
-		pj->pj_from = NULL;
-	if (pj->pj_to)
-		pj_free(pj->pj_to);
-		pj->pj_to = NULL;
-#else
 	if (pj->pj)
 		proj_destroy(pj->pj);
 		pj->pj = NULL;
-#endif
@@ -361,7 +348,6 @@ pjstrs_pfree(PjStrs *strs)
 		pfree(strs->srtext);
-#if POSTGIS_PROJ_VERSION >= 61
 static char*
 pgstrs_get_entry(const PjStrs *strs, int n)
@@ -377,25 +363,6 @@ pgstrs_get_entry(const PjStrs *strs, int n)
 			return NULL;
-#endif
-* Utility function for GML reader that still
-* needs proj4text access
-char *
-GetProj4String(int32_t srid)
-	PjStrs strs;
-	char *proj4str;
-	memset(&strs, 0, sizeof(strs));
-	strs = GetProjStringsSPI(srid);
-	proj4str = pstrdup(strs.proj4text);
-	pjstrs_pfree(&strs);
-	return proj4str;
-#endif
  * Add an entry to the local PROJ SRS cache. If we need to wrap around then
@@ -423,23 +390,6 @@ AddToPROJSRSCache(PROJSRSCache *PROJCache, int32_t srid_from, int32_t srid_to)
 	oldContext = MemoryContextSwitchTo(PROJCache->PROJSRSCacheContext);
-	PJ *projection = palloc(sizeof(PJ));
-	pj_from_str = from_strs.proj4text;
-	pj_to_str = to_strs.proj4text;
-	projection->pj_from = projpj_from_string(pj_from_str);
-	projection->pj_to = projpj_from_string(pj_to_str);
-	if (!projection->pj_from)
-		elog(ERROR,
-		    "could not form projection from 'srid=%d' to 'srid=%d'",
-		    srid_from, srid_to);
-	if (!projection->pj_to)
-		elog(ERROR,
-#else
 	LWPROJ *projection = NULL;
 	/* Try combinations of AUTH_NAME:AUTH_SRID/SRTEXT/PROJ4TEXT until we find */
@@ -463,7 +413,6 @@ AddToPROJSRSCache(PROJSRSCache *PROJCache, int32_t srid_from, int32_t srid_to)
 		elog(ERROR, "could not form projection (LWPROJ) from 'srid=%d' to 'srid=%d'", srid_from, srid_to);
 		return NULL;
-#endif
 	/* If the cache is already full then find the least used element and delete it */
 	uint32_t cache_position = PROJCache->PROJSRSCacheCount;
@@ -555,11 +504,7 @@ lwproj_lookup(int32_t srid_from, int32_t srid_to, LWPROJ **pj)
 int
 lwproj_is_latlong(const LWPROJ *pj)
-	return pj_is_latlong(pj->pj_from);
-#else
 	return pj->source_is_latlong;
-#endif
 static int
@@ -609,34 +554,13 @@ int
 spheroid_init_from_srid(int32_t srid, SPHEROID *s)
 	LWPROJ *pj;
-#if POSTGIS_PROJ_VERSION >= 48 && POSTGIS_PROJ_VERSION < 61
-	double major_axis, minor_axis, eccentricity_squared;
-#endif
 	if ( lwproj_lookup(srid, srid, &pj) == LW_FAILURE)
 		return LW_FAILURE;
 	if (!pj->source_is_latlong)
 		return LW_FAILURE;
 	spheroid_init(s, pj->source_semi_major_metre, pj->source_semi_minor_metre);
-#elif POSTGIS_PROJ_VERSION >= 48
-	if (!pj_is_latlong(pj->pj_from))
-	/* For newer versions of Proj we can pull the spheroid paramaeters and initialize */
-	/* using them */
-	pj_get_spheroid_defn(pj->pj_from, &major_axis, &eccentricity_squared);
-	minor_axis = major_axis * sqrt(1-eccentricity_squared);
-	spheroid_init(s, major_axis, minor_axis);
-#else
-	/* For old versions of Proj we cannot lookup the spheroid parameters from the API */
-	/* So we use the WGS84 parameters (boo!) */
-	spheroid_init(s, WGS84_MAJOR_AXIS, WGS84_MINOR_AXIS);
-#endif
 	return LW_SUCCESS;
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index c48a4117d..f7e130074 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -798,8 +798,6 @@ CREATE OR REPLACE FUNCTION _ST_CoveredBy(geog1 geography, geog2 geography)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
 -- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION ST_Covers(geog1 geography, geog2 geography)
 	RETURNS boolean
@@ -834,37 +832,6 @@ CREATE OR REPLACE FUNCTION ST_Intersects(geog1 geography, geog2 geography)
 	_COST_HIGH;
-#else /* POSTGIS_PGSQL_VERSION < 120 */
--- Only implemented for polygon-over-point
--- Availability: 1.5.0
-CREATE OR REPLACE FUNCTION ST_Covers(geog1 geography, geog2 geography)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Covers($1, $2)'
-	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
-CREATE OR REPLACE FUNCTION ST_CoveredBy(geog1 geography, geog2 geography)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Covers($2, $1)'
--- Changed: 3.0.0 to use default and named args
--- Replaces ST_DWithin(geography, geography, float8) deprecated in 3.0.0
-CREATE OR REPLACE FUNCTION ST_DWithin(geog1 geography, geog2 geography, tolerance float8, use_spheroid boolean DEFAULT true)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3, $4)'
-CREATE OR REPLACE FUNCTION ST_Intersects(geography, geography)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at .ST_Distance($1, $2, false) < 0.00001'
-#endif /* POSTGIS_PGSQL_VERSION < 120 */
 -- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
 CREATE OR REPLACE FUNCTION ST_Covers(text, text)
 	RETURNS boolean AS
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 56c685dfc..b7bf3e6a0 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -908,28 +908,6 @@ pg_nd_stats_from_tuple(HeapTuple stats_tuple, int mode)
 	if ( mode == 2 ) stats_kind = STATISTIC_KIND_2D;
     /* Then read the geom status histogram from that */
-		float4 *floatptr;
-		int nvalues;
-		rv = get_attstatsslot(stats_tuple, 0, 0, stats_kind, InvalidOid,
-							NULL, NULL, NULL, &floatptr, &nvalues);
-		if ( ! rv ) {
-			POSTGIS_DEBUGF(2, "no slot of kind %d in stats tuple", stats_kind);
-			return NULL;
-		/* Clone the stats here so we can release the attstatsslot immediately */
-		nd_stats = palloc(sizeof(float) * nvalues);
-		memcpy(nd_stats, floatptr, sizeof(float) * nvalues);
-		/* Clean up */
-		free_attstatsslot(0, NULL, 0, floatptr, nvalues);
-#else /* PostgreSQL 10 or higher */
 		AttStatsSlot sslot;
 		rv = get_attstatsslot(&sslot, stats_tuple, stats_kind, InvalidOid,
@@ -945,8 +923,6 @@ pg_nd_stats_from_tuple(HeapTuple stats_tuple, int mode)
 		free_attstatsslot(&sslot);
-#endif
 	return nd_stats;
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index 289d62a98..58f65dbd9 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -21,8 +21,6 @@
 /* PostgreSQL */
 #include "postgres.h"
 #include "funcapi.h"
@@ -542,5 +540,3 @@ Datum postgis_index_supportfn(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(ret);
-#endif /* POSTGIS_PGSQL_VERSION >= 120 */
diff --git a/postgis/lwgeom_accum.c b/postgis/lwgeom_accum.c
index 4b4a688c7..4ec33c852 100644
--- a/postgis/lwgeom_accum.c
+++ b/postgis/lwgeom_accum.c
@@ -337,25 +337,6 @@ pgis_geometry_clusterwithin_finalfn(PG_FUNCTION_ARGS)
 Datum
 PGISDirectFunctionCall1(PGFunction func, Datum arg1)
-	Datum           result;
-	InitFunctionCallInfoData(fcinfo, NULL, 1, InvalidOid, NULL, NULL);
-	/* Check for null result, returning a "NULL" Datum if indicated */
-		return (Datum) 0;
-	return result;
-#else
 	LOCAL_FCINFO(fcinfo, 1);
 	Datum result;
@@ -371,7 +352,6 @@ PGISDirectFunctionCall1(PGFunction func, Datum arg1)
 		return (Datum)0;
 	return result;
@@ -381,25 +361,6 @@ PGISDirectFunctionCall1(PGFunction func, Datum arg1)
 Datum
 PGISDirectFunctionCall2(PGFunction func, Datum arg1, Datum arg2)
-	Datum           result;
-	InitFunctionCallInfoData(fcinfo, NULL, 2, InvalidOid, NULL, NULL);
-		return (Datum) 0;
-	return result;
-#else
 	LOCAL_FCINFO(fcinfo, 2);
 	Datum result;
@@ -417,5 +378,4 @@ PGISDirectFunctionCall2(PGFunction func, Datum arg1, Datum arg2)
 		return (Datum)0;
 	return result;
diff --git a/postgis/lwgeom_in_gml.c b/postgis/lwgeom_in_gml.c
index 32b66af59..6fe568eb6 100644
--- a/postgis/lwgeom_in_gml.c
+++ b/postgis/lwgeom_in_gml.c
@@ -112,13 +112,6 @@ Datum geom_from_gml(PG_FUNCTION_ARGS)
 	/* Zero for undefined */
 	root_srid = PG_GETARG_INT32(1);
-	/* Internally lwgeom_from_gml calls gml_reproject_pa which, for PROJ before 6, called GetProj4String.
-	 * That function requires access to spatial_ref_sys, so in order to have it ready we need to ensure
-	 * the internal cache is initialized
-	postgis_initialize_cache();
-#endif
 	lwgeom = lwgeom_from_gml(xml, xml_size);
 	if ( root_srid != SRID_UNKNOWN )
 		lwgeom->srid = root_srid;
@@ -303,39 +296,6 @@ static xmlNodePtr get_xlink_node(xmlNodePtr xnode)
  * Use Proj to reproject a given POINTARRAY
-static POINTARRAY *
-gml_reproject_pa(POINTARRAY *pa, int32_t srid_in, int32_t srid_out)
-	LWPROJ pj;
-	char *text_in, *text_out;
-	if (srid_in == SRID_UNKNOWN) return pa; /* nothing to do */
-	if (srid_out == SRID_UNKNOWN) gml_lwpgerror("invalid GML representation", 3);
-	text_in = GetProj4String(srid_in);
-	text_out = GetProj4String(srid_out);
-	pj.pj_from = projpj_from_string(text_in);
-	pj.pj_to = projpj_from_string(text_out);
-	lwfree(text_in);
-	lwfree(text_out);
-	if ( ptarray_transform(pa, &pj) == LW_FAILURE )
-		elog(ERROR, "gml_reproject_pa: reprojection failed");
-	return pa;
-#else /* POSTGIS_PROJ_VERSION >= 61 */
 static POINTARRAY *
 gml_reproject_pa(POINTARRAY *pa, int32_t epsg_in, int32_t epsg_out)
@@ -374,9 +334,6 @@ gml_reproject_pa(POINTARRAY *pa, int32_t epsg_in, int32_t epsg_out)
 	return pa;
-#endif /* POSTGIS_PROJ_VERSION */
  * Return 1 if the SRS definition from the authority has a GIS friendly order,
  * that is easting,northing. This is typically true for most projected CRS
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 758e7996c..1f59b306e 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -152,13 +152,9 @@ Datum transform_geom(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(postgis_proj_version);
 Datum postgis_proj_version(PG_FUNCTION_ARGS)
-	const char *ver = pj_get_release();
-	text *result = cstring_to_text(ver);
-#else
 	PJ_INFO pji = proj_info();
 	text *result = 	cstring_to_text(pji.version);
-#endif
 	PG_RETURN_POINTER(result);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2c69ac5d6..4acf5ff12 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4577,107 +4577,6 @@ CREATE OR REPLACE FUNCTION ST_Equals(geom1 geometry, geom2 geometry)
 	_COST_HIGH;
-#else
--- Availability: 1.4.0
-CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(line1 geometry, line2 geometry)
-	RETURNS integer AS
-	$$ SELECT CASE WHEN NOT $1 OPERATOR(@extschema at .&&) $2 THEN 0 ELSE @extschema at ._ST_LineCrossingDirection($1,$2) END $$
--- Availability: 1.2.2
-CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry, float8)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_DWithin($1, $2, $3)'
-CREATE OR REPLACE FUNCTION ST_Touches(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Touches($1,$2)'
-CREATE OR REPLACE FUNCTION ST_Intersects(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Intersects($1,$2)'
-CREATE OR REPLACE FUNCTION ST_Crosses(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Crosses($1,$2)'
-CREATE OR REPLACE FUNCTION ST_Contains(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_Contains($1,$2)'
-CREATE OR REPLACE FUNCTION ST_CoveredBy(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .@) $2 AND @extschema at ._ST_CoveredBy($1,$2)'
-CREATE OR REPLACE FUNCTION ST_Covers(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_Covers($1,$2)'
-CREATE OR REPLACE FUNCTION ST_ContainsProperly(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .~) $2 AND @extschema at ._ST_ContainsProperly($1,$2)'
-CREATE OR REPLACE FUNCTION ST_Within(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $2 OPERATOR(@extschema at .~) $1 AND @extschema at ._ST_Contains($2,$1)'
-CREATE OR REPLACE FUNCTION ST_Overlaps(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_Overlaps($1,$2)'
-CREATE OR REPLACE FUNCTION ST_DFullyWithin(geom1 geometry, geom2 geometry, float8)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_DFullyWithin(@extschema at .ST_ConvexHull($1), @extschema at .ST_ConvexHull($2), $3)'
-CREATE OR REPLACE FUNCTION ST_3DDWithin(geom1 geometry, geom2 geometry,float8)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDWithin($1, $2, $3)'
-CREATE OR REPLACE FUNCTION ST_3DDFullyWithin(geom1 geometry, geom2 geometry,float8)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at .ST_Expand($1,$3) AND @extschema at ._ST_3DDFullyWithin($1, $2, $3)'
-CREATE OR REPLACE FUNCTION ST_3DIntersects(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .&&) $2 AND @extschema at ._ST_3DIntersects($1, $2)'
-CREATE OR REPLACE FUNCTION ST_OrderingEquals(GeometryA geometry, GeometryB geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .~=) $2 AND @extschema at ._ST_OrderingEquals($1, $2)'
--- Availability: 1.2.1
-CREATE OR REPLACE FUNCTION ST_Equals(geom1 geometry, geom2 geometry)
-	RETURNS boolean
-	AS 'SELECT $1 OPERATOR(@extschema at .~=) $2 AND @extschema at ._ST_Equals($1,$2)'
-#endif
 -- PostGIS equivalent function: IsValid(geometry)
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 593f64856..8f278d5f5 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -86,16 +86,12 @@ typedef struct {
 	Oid ufc_noid;
 	Oid ufc_rettype;
 	FmgrInfo ufl_info;
-	FunctionCallInfoData ufc_info;
-#else
 	/* copied from LOCAL_FCINFO in fmgr.h */
 	union {
 		FunctionCallInfoBaseData fcinfo;
 		char fcinfo_data[SizeForFunctionCallInfo(FUNC_MAX_ARGS)]; /* Could be optimized */
 	} ufc_info_data;
 	FunctionCallInfo ufc_info;
-#endif
 } rtpg_nmapalgebra_callback_arg;
 #if defined(__clang__)
@@ -155,9 +151,8 @@ static rtpg_nmapalgebra_arg rtpg_nmapalgebra_arg_init() {
 	arg->cextent = NULL;
 	arg->mask = NULL;
 	arg->callback.ufc_info = &(arg->callback.ufc_info_data.fcinfo);
-#endif
 	arg->callback.ufc_noid = InvalidOid;
 	arg->callback.ufc_rettype = InvalidOid;
@@ -491,30 +486,17 @@ static int rtpg_nmapalgebra_callback(
 	pfree(_pos);
 	pfree(_null);
-	callback->ufc_info.arg[0] = PointerGetDatum(mdValues);
-	callback->ufc_info.arg[1] = PointerGetDatum(mdPos);
-#else
 	callback->ufc_info->args[0].value = PointerGetDatum(mdValues);
 	callback->ufc_info->args[1].value = PointerGetDatum(mdPos);
-#endif
 	/* call user callback function */
-	datum = FunctionCallInvoke(&(callback->ufc_info));
-#else
 	datum = FunctionCallInvoke(callback->ufc_info);
-#endif
 	pfree(mdValues);
 	pfree(mdPos);
 	/* result is not null*/
-	if (!callback->ufc_info.isnull) {
-#else
 	if (!callback->ufc_info->isnull)
-#endif
 		switch (callback->ufc_rettype) {
 			case FLOAT8OID:
 				*value = DatumGetFloat8(datum);
@@ -871,11 +853,6 @@ Datum RASTER_nMapAlgebra(PG_FUNCTION_ARGS)
 			elog(NOTICE, "Function provided is VOLATILE. Unless required and for best performance, function should be IMMUTABLE or STABLE");
 		/* prep function call data */
-		InitFunctionCallInfoData(arg->callback.ufc_info, &(arg->callback.ufl_info), arg->callback.ufl_info.fn_nargs, InvalidOid, NULL, NULL);
-		memset(arg->callback.ufc_info.argnull, FALSE, sizeof(bool) * arg->callback.ufl_info.fn_nargs);
-#else
 		InitFunctionCallInfoData(*(arg->callback.ufc_info),
@@ -886,37 +863,19 @@ Datum RASTER_nMapAlgebra(PG_FUNCTION_ARGS)
 		arg->callback.ufc_info->args[0].isnull = FALSE;
 		arg->callback.ufc_info->args[1].isnull = FALSE;
 		arg->callback.ufc_info->args[2].isnull = FALSE;
-#endif
 		/* userargs (7) */
 		if (!PG_ARGISNULL(9))
-			arg->callback.ufc_info.arg[2] = PG_GETARG_DATUM(9);
-#else
 			arg->callback.ufc_info->args[2].value = PG_GETARG_DATUM(9);
-#endif
 		else {
       if (arg->callback.ufl_info.fn_strict) {
 				/* build and assign an empty TEXT array */
 				/* TODO: manually free the empty array? */
-				arg->callback.ufc_info.arg[2] = PointerGetDatum(
-					construct_empty_array(TEXTOID)
-				arg->callback.ufc_info.argnull[2] = FALSE;
-#else
 				arg->callback.ufc_info->args[2].value = PointerGetDatum(construct_empty_array(TEXTOID));
-#endif
 			else {
-				arg->callback.ufc_info.arg[2] = (Datum) NULL;
-				arg->callback.ufc_info.argnull[2] = TRUE;
-#else
 				arg->callback.ufc_info->args[2].value = (Datum)NULL;
 				arg->callback.ufc_info->args[2].isnull = TRUE;
-#endif
@@ -5131,11 +5090,8 @@ Datum RASTER_mapAlgebraFct(PG_FUNCTION_ARGS)
     int ret = -1;
     Oid oid;
     FmgrInfo cbinfo;
-    FunctionCallInfoData cbdata;
-#else
     LOCAL_FCINFO(cbdata, FUNC_MAX_ARGS); /* Could be optimized */
-#endif
     Datum tmpnewval;
     char * strFromText = NULL;
     int k = 0;
@@ -5375,19 +5331,11 @@ Datum RASTER_mapAlgebraFct(PG_FUNCTION_ARGS)
-    InitFunctionCallInfoData(cbdata, &cbinfo, 2, InvalidOid, NULL, NULL);
-    cbdata.argnull[0] = FALSE;
-    cbdata.argnull[1] = FALSE;
-    cbdata.argnull[2] = FALSE;
-#else
     InitFunctionCallInfoData(*cbdata, &cbinfo, 2, InvalidOid, NULL, NULL);
     cbdata->args[0].isnull = FALSE;
     cbdata->args[1].isnull = FALSE;
     cbdata->args[2].isnull = FALSE;
-#endif
     /* check that the function isn't strict if the args are null. */
     if (PG_ARGISNULL(4)) {
@@ -5401,20 +5349,11 @@ Datum RASTER_mapAlgebraFct(PG_FUNCTION_ARGS)
             PG_RETURN_NULL();
-	cbdata.arg[k] = (Datum)NULL;
-        cbdata.argnull[k] = TRUE;
-#else
-	cbdata->args[k].value = (Datum)NULL;
-	cbdata->args[k].isnull = TRUE;
-#endif
+		cbdata->args[k].value = (Datum)NULL;
+		cbdata->args[k].isnull = TRUE;
     else {
-	    cbdata.arg[k] = PG_GETARG_DATUM(4);
-#else
 	    cbdata->args[k].value = PG_GETARG_DATUM(4);
-#endif
@@ -5491,22 +5430,12 @@ Datum RASTER_mapAlgebraFct(PG_FUNCTION_ARGS)
                         POSTGIS_RT_DEBUG(3, "RASTER_mapAlgebraFct: Strict callbacks cannot accept NULL arguments, skipping NODATA cell.");
                         continue;
-		    cbdata.argnull[0] = TRUE;
-                    cbdata.arg[0] = (Datum)NULL;
-#else
 		    cbdata->args[0].isnull = TRUE;
 		    cbdata->args[0].value = (Datum)NULL;
-#endif
                 else {
-			cbdata.arg[0] = Float8GetDatum(r);
-#else
 			cbdata->args[0].value = Float8GetDatum(r);
-#endif
                 /* Add pixel positions if callback has proper # of args */
@@ -5519,32 +5448,19 @@ Datum RASTER_mapAlgebraFct(PG_FUNCTION_ARGS)
                     a = construct_array(d, 2, INT4OID, sizeof(int32), true, 'i');
-                    cbdata.arg[1] = PointerGetDatum(a);
-#else
 		    cbdata->args[1].value = PointerGetDatum(a);
-#endif
                 POSTGIS_RT_DEBUGF(3, "RASTER_mapAlgebraFct: (%dx%d), r = %f",
                     x, y, r);
-		tmpnewval = FunctionCallInvoke(&cbdata);
-                if (cbdata.isnull) {
-                    newval = newnodatavalue;
-#else
 		tmpnewval = FunctionCallInvoke(cbdata);
 		if (cbdata->isnull)
-#endif
 		else {
                     newval = DatumGetFloat8(tmpnewval);
@@ -5600,11 +5516,7 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
     int ret = -1;
     Oid oid;
     FmgrInfo cbinfo;
-#else
-#endif
     Datum tmpnewval;
     ArrayType * neighborDatum;
@@ -5851,15 +5763,10 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
-    InitFunctionCallInfoData(cbdata, &cbinfo, 3, InvalidOid, NULL, NULL);
-    memset(cbdata.argnull, FALSE, sizeof(bool) * 3);
-#else
     InitFunctionCallInfoData(*cbdata, &cbinfo, 3, InvalidOid, NULL, NULL);
-#endif
     if (PG_ARGISNULL(7)) {
@@ -5873,20 +5780,11 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
             PG_RETURN_NULL();
-	cbdata.arg[2] = (Datum)NULL;
-        cbdata.argnull[2] = TRUE;
-#else
 	cbdata->args[2].value = (Datum)NULL;
 	cbdata->args[2].isnull = TRUE;
-#endif
     else {
-	    cbdata.arg[2] = PG_GETARG_DATUM(7);
-#else
 	    cbdata->args[2].value = PG_GETARG_DATUM(7);
-#endif
@@ -6006,11 +5904,7 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
     memcpy((void *)VARDATA(txtCallbackParam), (void *)VARDATA(txtNodataMode), VARSIZE(txtNodataMode) - VARHDRSZ);
     /* pass the nodata mode into the user function */
-    cbdata.arg[1] = CStringGetDatum(txtCallbackParam);
-#else
     cbdata->args[1].value = CStringGetDatum(txtCallbackParam);
-#endif
     strFromText = text_to_cstring(txtNodataMode);
     strFromText = rtpg_strtoupper(strFromText);
@@ -6129,18 +6023,6 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
                 neighborDatum = construct_md_array((void *)neighborData, neighborNulls, 2, neighborDims, neighborLbs,
                     FLOAT8OID, typlen, typbyval, typalign);
-		/* Assign the neighbor matrix as the first argument to the user function */
-                cbdata.arg[0] = PointerGetDatum(neighborDatum);
-                /* Invoke the user function */
-                /* Get the return value of the user function */
-#else
 		cbdata->args[0].value = PointerGetDatum(neighborDatum);
@@ -6152,7 +6034,6 @@ Datum RASTER_mapAlgebraFctNgb(PG_FUNCTION_ARGS)
-#endif
 		else {
@@ -6261,11 +6142,8 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 	Oid ufc_noid = InvalidOid;
 	FmgrInfo ufl_info;
-#else
 	LOCAL_FCINFO(ufc_info, FUNC_MAX_ARGS); /* Could be optimized */
-#endif
 	int ufc_nullcount = 0;
 	int idx = 0;
@@ -6992,10 +6870,6 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
-				InitFunctionCallInfoData(ufc_info, &ufl_info, ufl_info.fn_nargs, InvalidOid, NULL, NULL);
-				memset(ufc_info.argnull, FALSE, sizeof(bool) * ufl_info.fn_nargs);
-#else
 				    *ufc_info, &ufl_info, ufl_info.fn_nargs, InvalidOid, NULL, NULL);
@@ -7003,22 +6877,11 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 				if (ufl_info.fn_nargs == 4)
 					ufc_info->args[3].isnull = FALSE;
-#endif
 				if (ufl_info.fn_nargs != 4)
 					k = 2;
 				else
 					k = 3;
-				if (!PG_ARGISNULL(7)) {
-					ufc_info.arg[k] = PG_GETARG_DATUM(7);
-				else {
-				 ufc_info.arg[k] = (Datum) NULL;
-				 ufc_info.argnull[k] = TRUE;
-				 ufc_nullcount++;
-#else
 					ufc_info->args[k].value = PG_GETARG_DATUM(7);
@@ -7029,7 +6892,6 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 					ufc_info->args[k].isnull = TRUE;
 					ufc_nullcount++;
-#endif
 			break;
@@ -7256,26 +7118,13 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 						/* build fcnarg */
 						for (i = 0; i < set_count; i++) {
-							ufc_info.arg[i] = Float8GetDatum(_pixel[i]);
-#else
 							ufc_info->args[i].value = Float8GetDatum(_pixel[i]);
-#endif
 							if (_haspixel[i]) {
-								ufc_info.argnull[i] = FALSE;
-#else
 								ufc_info->args[i].isnull = FALSE;
-#endif
 								ufc_nullcount--;
 							else {
-								ufc_info.argnull[i] = TRUE;
-#else
 								ufc_info->args[i].isnull = TRUE;
-#endif
 								ufc_nullcount++;
@@ -7301,24 +7150,10 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 							a = construct_array(d, 4, INT4OID, sizeof(int32), true, 'i');
-							ufc_info.arg[2] = PointerGetDatum(a);
-							ufc_info.argnull[2] = FALSE;
-#else
 							ufc_info->args[2].value = PointerGetDatum(a);
-#endif
-						datum = FunctionCallInvoke(&ufc_info);
-						/* result is not null*/
-						if (!ufc_info.isnull) {
-							haspixel = 1;
-							pixel = DatumGetFloat8(datum);
-#else
 						datum = FunctionCallInvoke(ufc_info);
@@ -7327,7 +7162,6 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 							haspixel = 1;
-#endif
 					}	break;
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 70366505a..1ceae8573 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -136,18 +136,14 @@ TESTS += \
 	$(top_srcdir)/regress/core/oriented_envelope \
 	$(top_srcdir)/regress/core/point_coordinates \
 	$(top_srcdir)/regress/core/out_geojson \
-  $(top_srcdir)/regress/core/wrapx
+  $(top_srcdir)/regress/core/wrapx \
+	$(top_srcdir)/regress/core/computed_columns
 # Slow slow tests
 TESTS_SLOW = \
 	$(top_srcdir)/regress/core/concave_hull_hard \
 	$(top_srcdir)/regress/core/knn_recheck
-ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 120),1)
-	TESTS += \
-		$(top_srcdir)/regress/core/computed_columns
-endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30700),1)
 	# GEOS-3.7 adds:
 	# ST_FrechetDistance
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index a59a145f6..ac08bd287 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -74,11 +74,7 @@ BEGIN
         FROM %1$I.edge
         WHERE left_face = $1 or right_face = $1
         ORDER BY
-#if POSTGIS_PGSQL_VERSION < 95
-          ST_Distance(geom, $2)
-#else
           geom <-> $2
-#endif
         LIMIT 1
       edgering AS (
Summary of changes:
 .github/workflows/ci.yml                    |   4 +-
 NEWS                                        |   3 +
 configure.ac                                |  12 +-
 doc/postgis.xml                             |   4 +-
 liblwgeom/liblwgeom.h.in                    |  36 +-----
 liblwgeom/lwgeom_transform.c                | 108 -----------------
 libpgcommon/lwgeom_pg.c                     |  40 -------
 libpgcommon/lwgeom_pg.h                     |   4 -
 libpgcommon/lwgeom_transform.c              |  78 +-----------
 postgis/geography.sql.in                    |  33 ------
 postgis/gserialized_estimate.c              |  24 ----
 postgis/gserialized_supportfn.c             |   4 -
 postgis/lwgeom_accum.c                      |  40 -------
 postgis/lwgeom_in_gml.c                     |  43 -------
 postgis/lwgeom_transform.c                  |   6 +-
 postgis/postgis.sql.in                      | 101 ----------------
 raster/rt_pg/rtpg_mapalgebra.c              | 176 +---------------------------
 regress/core/tests.mk.in                    |   8 +-
 topology/sql/manage/ValidateTopology.sql.in |   4 -
 19 files changed, 24 insertions(+), 704 deletions(-)
hooks/post-receive
