[postgis-tickets] [PostGIS] #5229: Drop support for Proj < 6.1 and PG 11 in PostGIS 3.4
PostGIS trac at osgeo.org
Sat Sep 3 10:40:49 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  task     |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"8d482e264cec6ab3903653bd8db41ffc404ca758/git" 8d482e2/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8d482e264cec6ab3903653bd8db41ffc404ca758"
 Fix debbie's make dist.  Needs to be > PG 11. References #5229 for PostGIS
 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5229#comment:5>
