[postgis-tickets] [PostGIS] #5229: Drop support for Proj < 6.1 and PG 11 in PostGIS 3.4
PostGIS trac at osgeo.org
Sat Sep 3 10:00:15 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  task     |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"be6b2ba84fbf90f0593f17d5e98fe98ba5f1d79f/git" be6b2ba/git]:
 {{{#!CommitTicketReference repository="git"
 revision="be6b2ba84fbf90f0593f17d5e98fe98ba5f1d79f"
 Upgrade dronie and gitlab runs to use PG > 11 and newer images that should
 have newer proj
 Closes #5230 for PostGIS 3.4.0
 Closes #5229 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5229#comment:4>
