[postgis-tickets] [PostGIS] #5231: PG15 no longer compiles against PostGIS 3.2 - 3.4 because SQL/JSON removed upstream (was: PG15 no longer compiles against PostGIS 3.2 - 3.4)
PostGIS trac at osgeo.org
Sat Sep 3 10:29:21 PDT 2022
upstream
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.2.4
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Changes (by robe):
 * summary:  PG15 no longer compiles against PostGIS 3.2 - 3.4 =>
     removed upstream
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5231#comment:2>
