[postgis-tickets] [PostGIS] #5231: PG15 no longer compiles against PostGIS 3.2 - 3.4 because SQL/JSON removed upstream
PostGIS trac at osgeo.org
Sat Sep 3 10:34:16 PDT 2022
upstream
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.2.4
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"ef24fcbe142aeca85169e42a5b13f84aff92b758/git"
 ef24fcbe/git]:
 {{{#!CommitTicketReference repository="git"
 revision="ef24fcbe142aeca85169e42a5b13f84aff92b758"
 Fix compile against > P15, References #5231 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5231#comment:3>
