[postgis-tickets] [PostGIS] #5231: PG15 no longer compiles against PostGIS 3.2 - 3.4 because SQL/JSON removed upstream
PostGIS trac at osgeo.org
Sat Sep 3 10:45:19 PDT 2022
upstream
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.2.4
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"2d8347668653a6d74ef435a040b343e310c5cf27/git" 2d83476/git]:
 {{{#!CommitTicketReference repository="git"
 revision="2d8347668653a6d74ef435a040b343e310c5cf27"
 Missed a spot, References #5231 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5231#comment:4>
