[postgis-tickets] [PostGIS] #5231: PG15 no longer compiles against PostGIS 3.2 - 3.4 because SQL/JSON removed upstream
PostGIS trac at osgeo.org
Sat Sep 3 10:59:42 PDT 2022
upstream
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.2.4
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"70e5060f1aa709c0db95333c2d997b71ce537706/git" 70e5060/git]:
 {{{#!CommitTicketReference repository="git"
 revision="70e5060f1aa709c0db95333c2d997b71ce537706"
 PG15 compile error with geojson out.  References #5231 for PostGIS 3.3.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5231#comment:5>
