[postgis-tickets] [PostGIS] #5231: PG15 no longer compiles against PostGIS 3.2 - 3.4 because SQL/JSON removed upstream
trac at osgeo.org
Sat Sep 3 12:04:03 PDT 2022
upstream
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.2.4
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Regina Obe <lr@…>):
In [changeset:"9921d5ce2a92966605341823807dbfe1d7487f38/git"
9921d5ce/git]:
{{{#!CommitTicketReference repository="git"
revision="9921d5ce2a92966605341823807dbfe1d7487f38"
PG15 compile error with geojson out. References #5231 for PostGIS 3.2.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5231#comment:6>
