[postgis-tickets] [SCM] postgis.net branch website updated. 8c5a66928ce742e2a7b0bdcf82f9a0f0fcb78d63
Sat Sep 10 11:37:06 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  8c5a66928ce742e2a7b0bdcf82f9a0f0fcb78d63 (commit)
      from  e24173701b73688c4f24f87893b43214f32e853b (commit)
revisions in full, below.
commit 8c5a66928ce742e2a7b0bdcf82f9a0f0fcb78d63
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Sep 10 14:37:02 2022 -0400
    Release PostGIS 3.3.1
diff --git a/config/_default/params.toml b/config/_default/params.toml
index d4b0de5..3f12b90 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -125,7 +125,7 @@ matomoDomain = "matomo.example.com" # Set to Matomo domain
 matomoSiteID = "1" # Default is set to 1, change this to the siteid being tracked
 [postgis]
-version = "3.3.0"
+version = "3.3.1"
 release_docs =  "https://download.osgeo.org/postgis/docs"
 release_source = "https://download.osgeo.org/postgis/source"
 release_notes = "https://git.osgeo.org/gitea/postgis/postgis/raw/tag"
@@ -141,8 +141,8 @@ dev_download = "/stuff"
     is_dev = true
   [postgis.releases.33]
     minor = "3.3"
-    dev = "3.3.1dev"
-    tag = "3.3.0"
+    dev = "3.3.2dev"
+    tag = "3.3.1"
   [postgis.releases.32]
     minor = "3.2"
     dev = "3.2.4dev"
diff --git a/content/post/2022/09-10_postgis-3.3.1.md b/content/post/2022/09-10_postgis-3.3.1.md
new file mode 100644
index 0000000..5f12f7a
--- /dev/null
+++ b/content/post/2022/09-10_postgis-3.3.1.md
@@ -0,0 +1,60 @@
+title: PostGIS 3.3.1
+layout: post
+category: news
+tags: [release,3.3]
+author: Regina Obe
+date: "2022-09-10"
+thumbnail:
+The PostGIS Team is pleased to release PostGIS 3.3.1.
+This is a bug fix release to address an issue compiling against PostgreSQL 15 Beta 4.
+Best served with [PostgreSQL 15 Beta 4](https://www.postgresql.org/about/news/postgresql-15-beta-4-released-2507/).
+<!--more-->
+**3.3.1**
+This release supports PostgreSQL 11 and higher, GEOS 3.6 and higher, and proj 5.2 and higher.
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.3.1.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.3.1/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.3.1.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.3.1.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-3.3/) [de]({{< loc "site.root">}}docs/manual-3.3/postgis-de.html) [ja]({{< loc "site.root">}}docs/manual-3.3/postgis-ja.html) [ko_KR]({{< loc "site.root">}}docs/manual-3.3/postgis-ko_KR.html)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.3.1.epub)
+**Bug Fixes**
+- [#5227](https://trac.osgeo.org/postgis/ticket/5227), typo in ST_LineLocatePoint error message (Sandro Santilli)
+- [#5231](https://trac.osgeo.org/postgis/ticket/5231), PG15 no longer compiles because SQL/JSON removed PG upstream (Regina Obe)
+Details of this release can be found in NEWS file:
+[https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.3.1/NEWS](https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.3.1/NEWS)
+and is also included in the source tar ball.
+If you come across any issues, feel free to report via our
+[ticket tracker](https://trac.osgeo.org/postgis)  or mailing list with details as described in [SUPPORT](https://postgis.net/support/)
+View all [closed tickets for 3.3.1][1].
+After installing the binaries or after running pg_upgrade:
+For upgrading from PostGIS 3.0, do the following which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.5 and below do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+[1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+3.3.1&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
Summary of changes:
 config/_default/params.toml              |  6 ++--
 content/post/2022/09-10_postgis-3.3.1.md | 60 ++++++++++++++++++++++++++++++++
 2 files changed, 63 insertions(+), 3 deletions(-)
 create mode 100644 content/post/2022/09-10_postgis-3.3.1.md
hooks/post-receive
postgis.net
